Unable to run two or more Bluetooth commands simultaneously
Hi all, I'm very new to arduino and currently doing a project on a RC car. The car works pretty fine but just one last thing that frustrates me which is the outputs (eg. when rear light left blinking signal is ON, I couldn't turn on the front lights). I always need to wait until the blinking rear light signal code is completely ended before I can start giving a new command..
Below is the coding I have done.. anyone can help?
char t;
int SPEED1 = 80;      // Steering Speed
int SPEED2 = 200;      // Engine Speed
pinMode(13,OUTPUT);   // Motor A forward
pinMode(12,OUTPUT);   // Motor A reverse
pinMode(11,OUTPUT);   // Motor B forward
pinMode(8,OUTPUT);    // Motor B reverse
pinMode(9,OUTPUT);    // Front LEDs (x2)
pinMode(5,OUTPUT);    // Left rear LEDS (x2)
pinMode(3,OUTPUT);    // Right rear LEDS (x2)
pinMode(10,OUTPUT);   // Voltage of Steering
pinMode(6,OUTPUT);    // Voltage of Engine
if(Serial.available()){
 t = Serial.read();
 Serial.println(t);
if(t == 'F'){            //Forward
 digitalWrite(8,HIGH);
 analogWrite(6,SPEED2);
else if(t == 'B'){      //Backward
 digitalWrite(11,HIGH);
else if(t == 'L'){      //Left
 analogWrite(10,SPEED1);
 digitalWrite(12,HIGH);
else if(t == 'R'){      //Right
 digitalWrite(13,HIGH);
else if(t == 'W'){      //Frontlights ON with 30 magnitude
 analogWrite(9,30);
else if(t == 'w'){      //Frontlights OFF
 analogWrite(9,0);
else if(t == 'V'){      //Rearlights ON with 30 magnitude
 analogWrite(5,30);
 analogWrite(3,30);
else if(t == 'v'){      //Rearlights OFF
 analogWrite(5,0);
 analogWrite(3,0);
else if(t == 'A'){      //Left Blinking Signal
 analogWrite(5,0);
 analogWrite(5,30);
 analogWrite(5,0);
 analogWrite(5,30);
 analogWrite(5,0);
else if(t == 'Q'){      //Right Blinking Signal
 analogWrite(3,0);
 analogWrite(3,30);
 analogWrite(3,0);
 analogWrite(3,30);
 analogWrite(3,0);
else if(t == 'S'){      //STOP (all motors stop)
 digitalWrite(13,LOW);
 digitalWrite(12,LOW);
 digitalWrite(11,LOW);
 digitalWrite(8,LOW);
You can not use delay() in your sketch if you want it to respond to more input while doing something. Look at the Blink Without Delay example in the IDE (File->Examples-02.Digital->Blink Without Delay). You can also look at the Several Things at the same time example
