I tried to send a code to my AC but have no output to my LED. I'm using an Arduino Uno, the IRremote.h library was modified with #define RAWBUF 800
The hardware is well connected, with IR LED on pin 3 and with a 220 ohm resistor on GND, tested with a modified Blink sketch.
Using last IRremote library 3.3.0 and tested the code from this link (IR Remote control of Air Conditioner - Can't get it to work), still have no output to IR LED and also noticed the TX LED from Uno always stays ON.
Please help, I don't know what I'm doing wrong. Thank you!
* IRremote: IRsendRawDemo - demonstrates sending IR codes with sendRaw
* An IR LED must be connected to Arduino PWM pin 3.
* Version 0.1 July, 2009
* Copyright 2009 Ken Shirriff
* http://arcfn.com
* IRsendRawDemo - added by AnalysIR (via www.AnalysIR.com), 24 August 2015
#include <IRremote.h>
IRsend irsend;
int khz = 38; // 38kHz carrier frequency for the NEC protocol
unsigned int irSignal[] = {3552, 1664, 508, 364, 508, 1232, 504, 364, 508, 360, 508, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 504, 1236, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 504, 364, 508, 364, 504, 1232, 508, 1232, 480, 1256, 484, 392, 480, 388, 480, 1256, 484, 388, 480, 388, 480, 392, 504, 364, 480, 388, 508, 360, 508, 364, 480, 388, 504, 364, 508, 364, 504, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 504, 368, 504, 364, 504, 364, 504, 364, 508, 364, 504, 364, 508, 360, 508, 364, 504, 364, 504, 364, 508, 364, 504, 368, 476, 392, 476, 392, 480, 1256, 484, 1256, 508, 364, 504, 364, 504, 364, 508, 360, 508, 364, 504, 10884, 3528, 1688, 504, 368, 504, 1232, 484, 384, 484, 388, 484, 384, 484, 384, 484, 384, 484, 392, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 508, 1228, 508, 364, 504, 364, 508, 364, 504, 364, 504, 368, 504, 364, 504, 364, 504, 1232, 508, 1232, 508, 1232, 504, 364, 508, 364, 504, 1232, 504, 364, 508, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 1236, 504, 1232, 480, 1260, 484, 384, 484, 384, 484, 384, 484, 388, 484, 384, 508, 368, 476, 1256, 508, 1228, 512, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 1236, 504, 1232, 504, 364, 508, 364, 504, 364, 504, 1236, 504, 1232, 480, 388, 480, 392, 484, 384, 480, 388, 484, 388, 484, 384, 484, 384, 484, 392, 480, 388, 480, 388, 480, 388, 508, 364, 504, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 508, 364, 504, 1232, 504, 1236, 504, 1232, 504, 364, 508, 364, 504, 364, 480, 388, 480, 392, 476, 392, 480, 392, 480, 388, 480, 392, 480, 1252, 512, 1232, 504, 1232, 508, 364, 504, 364, 504, 364, 504, 368, 504, 364, 504, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 508, 368, 472, 396, 476, 392, 476, 392, 476, 396, 476, 1256, 484, 392, 476, 392, 480, 388, 480, 388, 508, 364, 504, 364, 504, 1236, 504, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 504, 364, 508, 364, 504, 364, 504, 364, 508, 364, 504, 368, 500, 368, 500, 368, 476, 396, 476, 392, 476, 392, 476, 1260, 484, 1252, 484, 1260, 480, 388, 504, 364, 508, 364, 504, 1232, 508};
irsend.sendRaw(irSignal, sizeof(irSignal) / sizeof(irSignal[0]), khz); //Note the approach used to automatically calculate the size of the array.
delay(5000); //In this example, the signal will be repeated every 5 seconds, approximately.
