Unable to set color text in a RGBLED matrix connected to ESP32
after three days of useless attempts (that just confirmed my suspect that I'm a dumb old(74) newbie) I'm asking for help for this maybe trivial issue.
I'm trying to change colour of the text in a 64x64 RGBLED Waveshare matrix connected to an ESP32.
By using GPxMatrix library I was able to display data from a BME280 and from a RTC DS3231 but everything is just in white color.
The matrix has a separate 5V power source ( 10 A ) and the grounds of the matrix and of the ESP32 are connected.
The examples available on the web for this libray are from tawi/Great Projects and show amazing effects but all the videos are without comments and I was not able to extract from the linked codes a simple instruction to set the color of the text.
I've also tried other libraries ( SmartMatrix, Adafruit RGB_matrix) but without any success. For Adafruit libraries it seems that with ESP32 one should use the Adafruit Protomatter but I was not able to get it work.
I tried to read discussions on this topic on the web ( for example MarcMerlin) but they are really above my level .
If in my code I use the command matrix.setTextColor(matrix.Color333(0, 0, 7)); it seems to work but blue is the only colour that is displayed while other colours are simply ignored (either the text si not displayed or it is displayed in blue).
Where is my mistake ?
Could someone suggest a simple way to achieve the result of changing the color of the text ? Thanks in advance for your eagerly needed help.
Here is the code ( if I comment the lines matrix.setTextColor(matrix.Color333(etc)) it works fine but everything is displayed in white and if I uncomment the se lines either everything is displayed in blue or some lines of the text are not displayed at all.
#include<Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <RTClib.h>
#include <Adafruit_GFX.h>
// Define custom I2C pins
#define I2C_SDA 18
#define I2C_SCL 21
Adafruit_BME280 bme;
RTC_DS3231 rtc;
#include <GPxMatrix.h>\
#define P_A    23
#define P_B    22
#define P_C    5
#define P_D    17
#define P_E    32
#define P_CLK  16
#define P_LAT  4
#define P_OE   15
uint8_t listrgbpins[6] = {25, 26, 27, 14, 12, 13};
GPxMatrix matrix(P_A, P_B, P_C, P_D, P_E, P_CLK, P_LAT, P_OE, false, 64, listrgbpins);
  delay(100);
    // Initialize I2C with custom pins
  Wire.begin(I2C_SDA, I2C_SCL);
  bool status;
  status = bme.begin(0x76, &Wire);
  if (!status) {
    Serial.println("Could not find a valid BME280 sensor, check wiring!");
    while (1);
 // initializing the rtc
   if(!rtc.begin()) {
        Serial.println("Couldn't find RTC!");
        Serial.flush();
        while (1) delay(10);
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
DateTime now = rtc.now();
char dateBuffer[12];
uint16_t myRED = matrix.Color333(7, 0, 0);
uint16_t myGREEN = matrix.Color333(0, 7, 0);
uint16_t myBLUE = matrix.Color333(0, 0, 7);
 matrix.begin();
  // fill the screen with 'black'
  matrix.fillScreen(0);
  sprintf(dateBuffer,"%02u-%02u-%04u ",now.day(),now.month(),now.year());
  Serial.print(dateBuffer);
  sprintf(dateBuffer,"%02u:%02u:%02u ",now.hour(),now.minute(),now.second());
  Serial.println(dateBuffer);
  Serial.print("Temperature = ");
  Serial.print(bme.readTemperature());
  Serial.println(" *C");
  Serial.print("Humidity = ");
  Serial.print(bme.readHumidity());
  Serial.println(" %");
  matrix.setTextSize(1);     // size 1 == 8 pixels high
  matrix.setTextWrap(true);
  matrix.setCursor(4, 0);
  matrix.setTextColor(matrix.Color333(0, 7, 0));
  matrix.print("T= ");
  matrix.setCursor(20, 0);
  matrix.print(bme.readTemperature());
  matrix.println(" C");
  matrix.setCursor(4, 10);
  matrix.setTextColor(matrix.Color333(7, 0, 0));
  matrix.print("H= ");
  matrix.setCursor(20, 10);
  matrix.print(bme.readHumidity());
  matrix.println(" %");
  matrix.setCursor(4,25);
  matrix.print(dateBuffer);
  matrix.setCursor(4,35);
  matrix.setCursor(4,45);
  matrix.print("Have a nice day");
  delay(5000);
Does it mean that you able to output the text to the matrix and whole problem is that you can do it with one color and can't change it to another?
does this not work?
Hi all,
Yes, my problem is to change color of the text while using this library and this RGB LED matrix from Waveshare.
I've tried several combinations of colors and it seems that with command matrix.setTextColor(r,g,b) (with r, g and b from 0 to 7) any combination that has b equal to 7 displays text in the same color blue, while every other combination that has b different from 7 (obviously less than 7) simply does not display anything.
The pins R1, G1 and B1 of my HUB75 are connected to pins 25, 26 and 27 of the ESP32 and the pins R2, G2 and B2 are connected to pins 14, 17 and 13, as requested in the instructions of Waveshare 64x64 RGB LED matrix.
Here is a very simple code that in my hands shows the strange behaviour I've just described (and shown in the comments).
Is there any way to fix this issue ?
Thanks again
#define P_A    23
#define P_B    22
#define P_C    5
#define P_D    17
#define P_E    32
#define P_CLK  16
#define P_LAT  4
#define P_OE   15
/* standard colors
uint16_t myRED = matrix.Color333(7,0,0); //no text is displayed with this setup
uint16_t myGREEN = matrix.Color333(0,7,0); //no text is displayed with this setup
uint16_t myBLUE = matrix.Color333(0,0,7); // text is displayed in blue
uint16_t myWHITE = matrix.Color333(7, 7,7); // text is displayed in blue
uint16_t myYELLOW = matrix.Color333(7,7,0); //no text is displayed with this setup
uint16_t myCYAN = matrix.Color333(0,7,7);  // text is displayed in blue
uint16_t myMAGENTA = matrix.Color333(7,0,7); // text is displayed in blue
uint16_t myShadow = matrix.Color333(4,0,7); // text is displayed in blue
uint16_t myROSE = matrix.Color333(7,0,4); //no text is displayed with this setup
uint16_t myBLACK = matrix.Color333(0,0,0);
   matrix.begin();
  matrix.setTextColor(matrix.Color333(7,0,4)); //no text is displayed with this setup
  matrix.setCursor(4, 4);
  matrix.print("Hello");
    delay(5000);
Hi again
Just to inform you that I was able to solve - at least partially - my problem.
Here is the code that for the defined colors seems to work fine; however you can see that yellow color is not available (however ORANGE is very close)
I adapted a code by Marc Merlin found in the example PanelGFX_Demo_64x128.
Hope this can save time to someone else.
Have a nice day
// RGB Panel GFX Demo example for 16x32 panel
// By Marc MERLIN <marc_soft@merlins.org>
// Contains code (c) Adafruit, license BSD
// WILL NOT FIT on ARDUINO UNO -- requires a Mega, M0 or M4 board
#define P_A    23
#define P_B    22
#define P_C    5
#define P_D    17
#define P_E    32
#define P_CLK  16
#define P_LAT  4
#define P_OE   15
//                          R1, G1, B1, R2, G2, B2  (RGB Pins)
GPxMatrix *matrix = new GPxMatrix(P_A, P_B, P_C, P_D, P_E, P_CLK, P_LAT, P_OE, true, 64, listrgbpins);
//GPxMatrix *matrix = new GPxMatrix(P_A, P_B, P_C, P_D, P_E, P_CLK, P_LAT, P_OE, false, 64);   // Enable double buffering
// Panel Matrix doesn't fully work like Neomatrix (which I originally
// wrote this demo for), so map a few calls to be compatible. The rest
// comes from Adafruit_GFX and works the same on both backends.
#define clear()          fillScreen(0)
#define show()           swapBuffers(true)
#define Color(x,y,z)     Color888(x,y,z)
// Define matrix width and height.
#define mw 64  // original was 128
#define mh 64
// This could also be defined as matrix->color(255,0,0) but those defines
// are meant to work for Adafruit::GFX backends that are lacking color()
#define LED_BLACK           0
#define LED_RED_VERYLOW    (3 <<  11)
#define LED_RED_LOW        (7 <<  11)
#define LED_RED_MEDIUM     (15 << 11)
#define LED_RED_HIGH       (31 << 11)
#define LED_GREEN_VERYLOW  (1 <<  5)
#define LED_GREEN_LOW      (15 << 5)
#define LED_GREEN_MEDIUM   (31 << 5)
#define LED_GREEN_HIGH     (63 << 5)
#define LED_BLUE_VERYLOW     3
#define LED_BLUE_LOW         7
#define LED_BLUE_MEDIUM     15
#define LED_BLUE_HIGH       31
#define LED_ORANGE_VERYLOW (LED_RED_VERYLOW + LED_GREEN_VERYLOW)
#define LED_ORANGE_LOW     (LED_RED_LOW     + LED_GREEN_LOW)
#define LED_ORANGE_MEDIUM  (LED_RED_MEDIUM  + LED_GREEN_MEDIUM)
#define LED_ORANGE_HIGH    (LED_RED_HIGH    + LED_GREEN_HIGH)
#define LED_PURPLE_VERYLOW (LED_RED_VERYLOW + LED_BLUE_VERYLOW)
#define LED_PURPLE_LOW     (LED_RED_LOW     + LED_BLUE_LOW)
#define LED_PURPLE_MEDIUM  (LED_RED_MEDIUM  + LED_BLUE_MEDIUM)
#define LED_PURPLE_HIGH    (LED_RED_HIGH    + LED_BLUE_HIGH)
#define LED_CYAN_VERYLOW   (LED_GREEN_VERYLOW + LED_BLUE_VERYLOW)
#define LED_CYAN_LOW       (LED_GREEN_LOW     + LED_BLUE_LOW)
#define LED_CYAN_MEDIUM    (LED_GREEN_MEDIUM  + LED_BLUE_MEDIUM)
#define LED_CYAN_HIGH      (LED_GREEN_HIGH    + LED_BLUE_HIGH)
#define LED_WHITE_VERYLOW  (LED_RED_VERYLOW + LED_GREEN_VERYLOW + LED_BLUE_VERYLOW)
#define LED_WHITE_LOW      (LED_RED_LOW     + LED_GREEN_LOW     + LED_BLUE_LOW)
#define LED_WHITE_MEDIUM   (LED_RED_MEDIUM  + LED_GREEN_MEDIUM  + LED_BLUE_MEDIUM)
#define LED_WHITE_HIGH     (LED_RED_HIGH    + LED_GREEN_HIGH    + LED_BLUE_HIGH)
    matrix->begin();
    matrix->setTextWrap(false);
    matrix->fillScreen(LED_GREEN_MEDIUM);
    matrix->show();
    delay(2000);
    matrix->clear();
  matrix->clear();
    matrix->setTextWrap(true);  // we don't wrap text so it scrolls nicely
    matrix->setTextSize(1);
    matrix->setRotation(0);
    matrix->setCursor(2,2);
    matrix->setTextColor(LED_CYAN_HIGH);
    matrix->print(" Hello ");
    matrix->setTextColor(LED_PURPLE_HIGH);
    matrix->print(" World  ");
   matrix->show();
    delay(1500);
  matrix->clear();
  matrix->fillScreen(LED_BLACK);
  matrix->show();
  delay(1500);
Given --
I'd figure --
#define LED_YELLOW_MEDIUM  (LED_RED_LOW  + LED_GREEN_MEDIUM)
#define LED_YELLOW_HIGH    (LED_RED_LOW  + LED_GREEN_HIGH)
I like to use these full and half bright colors.
int orbitColor[10][4] = {
  {255, 255, 255}, // wht
  {255,   0,   0}, // red
  {255, 127,   0}, // org
  {255, 255,   0}, // yel
  {  0, 255,   0}, // grn
  {  0, 255, 255}, // cyn
  {  0, 127, 127}, // tel
  {  0,   0, 255}, // blu
  {255,   0, 255}, // pur
  {128,   0, 128}  // mag
In Search of --
Indigo
Hi, thanks for your help.
I've tried your suggestion and it works fine: it displays a yellow colour with a very slight green hue but distinctly different from orange... so the palette of colours is growing.
Good luck in your search for indigo.
Have a nice day
Hi, sorry for the maybe silly question (but as I said before I'm an old -74 - newbie) how can I use your suggestion in my code with the GPxMatrix I'm using. ?
Thanks for your help
Your code assigns names to intensity levels like "LOW" or "MEDIUM" or "HIGH"... The numbers I showed are just the value of your names, ranging from 0 to 255 (intensity of color). You can see I only use 0, 127 and 255 (off, middle, high) to define ten colors, what I call "primary" (red, green, blue, white) and secondary (yellow, orange, cyan, teal (a dark cyan), magenta, purple (a dark magenta).
In the numbers I show, the color placement is RED, GREEN, BLUE, so orange is full red (255), half green (127), and no blue(0).
I hope this helped.
This codes are for Color(x,y,z) function, defined in your code.
Ok thanks
I'll try
Have a nice day
Hi
Thanks for your prompt answer : this weekend I'm going to try a good number of values combinations just to check if I've correctly understood how it works
Warm up band for/and Deep Purple. (127, 0, 255)
I spent some time trying different value combinations _ according to your suggestion - and they work quite fine. Thanks really for your help.
Now, if I can bother you again, since I solved the problem of displaying different colours for text on my RGB LED matrix ( and also getting text scrolling ) I tried to display some very simple images. With TFT and OLED displays I was able to resize the image for the screen resolution, convert the image to the proper format and to display it ( using an array, as usual).
I tried the same process with my RGB LED matrix but without any success.
Even using a monochrome image I'm just getting the right color but not a discernible image.
I googled extensively trying to find tutorials and/or step by step instructions to obtain this result but I was not able to find anything for the GPxMatrix I'm using and when I tried to use the examples of SmartMatrix library a overwhelming mass of compilation errors came out and I was unable to understand how to solve this issue.
However, probably I have to open a new post for this issue since I don't want to violate the forum rules...
Here is a 12x12 Neopixel (one-wire controllable RGBLED) simulation of a real picture of a person sitting at a table, with a light-green background.
The result speaks for itself. I can't squint hard enough to see the original picture.
Displaying the image on RGB matrix is quite the same as on TFT and OLED displays. But you have to consider the lower resolution and lower color depth.
Tell us in more detail how you tried to do this and show your code
Typical images usually too dim and contain small details. For the RGB panels you need to select special pictures, with bright contrasting colors, and in the pixel art style.
(64x64 RGB panel, STM32F103 bluepill board with DMD_STM32 library:
Hi, thanks for your prompt answer and the time you're spending to help me.
First of all, I have to say that I was not able to find a single example of an image displayed using GPxMatrix library ( for example Brian Lough shows an image of SuperMario but he uses PxMatrix library)
When I tried to use the GPxMatrix library (that works fine with text) to display an image I met the problem that the display was showing a garbage of lit pixels without any discernible image
These are the steps I followed
  1. I chose a very simple image such as a monochrome stylized heart
    heart
  2. then I resized it to 64x64 pixels by using GIMP
  3. then I converted to an array by using LVGL Image online converter ( and I tried both the RGB565option and the RGB888 option)
  4. then i tried to display the image by using this code
#define P_A    23
#define P_B    22
#define P_C    5
#define P_D    17
#define P_E    32
#define P_CLK  16
#define P_LAT  4
#define P_OE   15
#define LED_BLACK           0
//Original comments from the Author of the code Marc Merlin
#define mh 64
void fixdrawRGBBitmap(int16_t x, int16_t y, const uint16_t *bitmap, int16_t w, int16_t h) {
    uint16_t RGB_bmp_fixed[w * h];
    for (uint16_t pixel=0; pixel<w*h; pixel++) {
        uint8_t r,g,b;
        uint16_t color = pgm_read_word(bitmap + pixel);
        //Serial.print(color, HEX);
        b = (color & 0xF00) >> 8;
        g = (color & 0x0F0) >> 4;
        r = color & 0x00F;
        //Serial.print(" ");
        //Serial.print(b);
        //Serial.print("/");
        //Serial.print(g);
        //Serial.print(r);
        //Serial.print(" -> ");
        // expand from 4/4/4 bits per color to 5/6/5
        b = map(b, 0, 15, 0, 31);
        g = map(g, 0, 15, 0, 63);
        r = map(r, 0, 15, 0, 31);
        //Serial.print(r);
        //Serial.print(g);
        //Serial.print(b);
        RGB_bmp_fixed[pixel] = (r << 11) + (g << 5) + b;
        //Serial.println(RGB_bmp_fixed[pixel], HEX);
    matrix->drawRGBBitmap(x, y, RGB_bmp_fixed, w, h);
const unsigned short heart[] PROGMEM={
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFC30, 0xFA28, 0xF924,   // 0x0010 (16) pixels
0xF9E7, 0xF8C3, 0xF945, 0xFA08, 0xF9E7, 0xFA69, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0020 (32) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA49, 0xF9A6, 0xFA28, 0xF904, 0xF8C3, 0xFA08,   // 0x0030 (48) pixels
0xF986, 0xFA8A, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0040 (64) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFBAE, 0xFC10, 0xFA28, 0xF924,   // 0x0050 (80) pixels
0xF9E7, 0xF8C3, 0xF945, 0xFA08, 0xF9E7, 0xFA69, 0xFB4D, 0xFAAA, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0060 (96) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFB0C, 0xFB8E, 0xFA49, 0xF9A6, 0xFA28, 0xF904, 0xF8C3, 0xFA08,   // 0x0070 (112) pixels
0xF986, 0xFA8A, 0xFB8E, 0xFACB, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0080 (128) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFB4D, 0xF9A6, 0xF924, 0xF904, 0xF8A2, 0xF861,   // 0x0090 (144) pixels
0xF8E3, 0xF841, 0xF882, 0xF8E3, 0xF8C3, 0xF8A2, 0xF8E3, 0xF986, 0xFA49, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00A0 (160) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFE18, 0xF9E7, 0xF945, 0xF8E3, 0xF8A2, 0xF8A2, 0xF904, 0xF861, 0xF841, 0xF8E3,   // 0x00B0 (176) pixels
0xF882, 0xF8C3, 0xF8E3, 0xF945, 0xF9C7, 0xFDB6, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00C0 (192) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFBAE, 0xF9A6, 0xF924, 0xF8E3, 0xF8A2, 0xF861, 0xF800, 0xF800,   // 0x00D0 (208) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF882, 0xF8E3, 0xF904, 0xF945, 0xFA28, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x00E0 (224) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0xFEDB, 0xF9E7, 0xF965, 0xF8E3, 0xF8C3, 0xF861, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x00F0 (240) pixels
0xF800, 0xF800, 0xF882, 0xF8C3, 0xF8E3, 0xF945, 0xF9E7, 0xFF5D, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0100 (256) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA49, 0xF986, 0xF924, 0xF8A2, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0110 (272) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8E3, 0xF945, 0xF9A6, 0xFB6D, 0x0000, 0x0000, 0x0000,   // 0x0120 (288) pixels
0x0000, 0x0000, 0x0000, 0xFAAA, 0xF986, 0xF945, 0xF8C3, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0130 (304) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xF945, 0xF9A6, 0xFAAA, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0140 (320) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF9E7, 0xF9E7, 0xF9A6, 0xF8C3, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0150 (336) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF945, 0xF9E7, 0xFA8A, 0x0000, 0x0000,   // 0x0160 (352) pixels
0x0000, 0xFA28, 0xFA08, 0xF9A6, 0xF904, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0170 (368) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF904, 0xF9A6, 0xFA28, 0xFA49, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0180 (384) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0xFA28, 0xF9E7, 0xF986, 0xF882, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0190 (400) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF8E3, 0xFA08, 0xFA8A, 0x0000,   // 0x01A0 (416) pixels
0x0000, 0xFA08, 0xF9A6, 0xF8A2, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x01B0 (432) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF8A2, 0xF9C7, 0xFA28, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x01C0 (448) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0xFA08, 0xF9E7, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x01D0 (464) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF904, 0xFA69, 0xFAEB,   // 0x01E0 (480) pixels
0xFA49, 0xF9E7, 0xF8C3, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x01F0 (496) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF8C3, 0xFA08, 0xFA69, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0200 (512) pixels
0x0000, 0x0000, 0x0000, 0xFA08, 0xF9E7, 0xF8E3, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0210 (528) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF861, 0xF924, 0xFA8A,   // 0x0220 (544) pixels
0xFA28, 0xF8E3, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0230 (560) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF904, 0xFA69, 0xFACB, 0x0000, 0x0000, 0x0000,   // 0x0240 (576) pixels
0x0000, 0x0000, 0xFA69, 0xFA08, 0xF924, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0250 (592) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF882, 0xF986,   // 0x0260 (608) pixels
0xF945, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0270 (624) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF861, 0xF965, 0xFAAA, 0x0000, 0x0000, 0x0000,   // 0x0280 (640) pixels
0x0000, 0x0000, 0xFA8A, 0xF986, 0xF861, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0290 (656) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8E3,   // 0x02A0 (672) pixels
0xF8A2, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x02B0 (688) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xFA08, 0xFA28, 0x0000, 0x0000,   // 0x02C0 (704) pixels
0x0000, 0xFB0C, 0xFA49, 0xF904, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x02D0 (720) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x02E0 (736) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x02F0 (752) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF965, 0xFA69, 0xFBCF, 0x0000,   // 0x0300 (768) pixels
0x0000, 0xFA28, 0xF9E7, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0310 (784) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0320 (800) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0330 (816) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xFA8A, 0xFB0C, 0x0000,   // 0x0340 (832) pixels
0x0000, 0xF986, 0xF945, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0350 (848) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0360 (864) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0370 (880) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF9C7, 0xF9E7, 0x0000,   // 0x0380 (896) pixels
0xFB4D, 0xFA49, 0xF8C3, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0390 (912) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x03A0 (928) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x03B0 (944) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF945, 0xF965, 0x0000,   // 0x03C0 (960) pixels
0xFA69, 0xFA08, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x03D0 (976) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x03E0 (992) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x03F0 (1008) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xFAAA, 0xFBCF,   // 0x0400 (1024) pixels
0xF9E7, 0xF9A6, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0410 (1040) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0420 (1056) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0430 (1072) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xFA69, 0xFAEB,   // 0x0440 (1088) pixels
0xF986, 0xF965, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0450 (1104) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0460 (1120) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0470 (1136) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF9E7, 0xFA49,   // 0x0480 (1152) pixels
0xF986, 0xF965, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0490 (1168) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x04A0 (1184) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x04B0 (1200) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF9C7, 0xF9E7,   // 0x04C0 (1216) pixels
0xF924, 0xF904, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x04D0 (1232) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x04E0 (1248) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x04F0 (1264) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF9A6, 0xF9E7,   // 0x0500 (1280) pixels
0xF965, 0xF945, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0510 (1296) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0520 (1312) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0530 (1328) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF9C7, 0xF9E7,   // 0x0540 (1344) pixels
0xF965, 0xF945, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0550 (1360) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0560 (1376) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0570 (1392) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF9C7, 0xFA08,   // 0x0580 (1408) pixels
0xF986, 0xF965, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0590 (1424) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x05A0 (1440) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x05B0 (1456) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xFA08, 0xFA69,   // 0x05C0 (1472) pixels
0xF9E7, 0xF9A6, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x05D0 (1488) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x05E0 (1504) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x05F0 (1520) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF861, 0xFA69, 0xFB0C,   // 0x0600 (1536) pixels
0xFA69, 0xFA08, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0610 (1552) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0620 (1568) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0630 (1584) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF8E3, 0xFACB, 0xED55,   // 0x0640 (1600) pixels
0xF3CF, 0xFA69, 0xF8C3, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0650 (1616) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0660 (1632) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0670 (1648) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF965, 0xF9C7, 0x0000,   // 0x0680 (1664) pixels
0x0000, 0xF9C7, 0xF924, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0690 (1680) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x06A0 (1696) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x06B0 (1712) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF9E7, 0xFA08, 0x0000,   // 0x06C0 (1728) pixels
0x0000, 0xF9A6, 0xF986, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x06D0 (1744) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x06E0 (1760) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x06F0 (1776) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8A2, 0xFA49, 0xFACB, 0x0000,   // 0x0700 (1792) pixels
0x0000, 0xFA8A, 0xFA08, 0xF8A2, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0710 (1808) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0720 (1824) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0730 (1840) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF924, 0xFA69, 0xFC30, 0x0000,   // 0x0740 (1856) pixels
0x0000, 0x0000, 0xFA8A, 0xF924, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0750 (1872) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0760 (1888) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0770 (1904) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF861, 0xF9C7, 0xF9E7, 0x0000, 0x0000,   // 0x0780 (1920) pixels
0x0000, 0x0000, 0xF9E7, 0xF9A6, 0xF861, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0790 (1936) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x07A0 (1952) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x07B0 (1968) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF904, 0xFAAA, 0xFBAE, 0x0000, 0x0000,   // 0x07C0 (1984) pixels
0x0000, 0x0000, 0xFB6D, 0xFA49, 0xF904, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x07D0 (2000) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x07E0 (2016) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x07F0 (2032) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF861, 0xF9C7, 0xFA49, 0x0000, 0x0000, 0x0000,   // 0x0800 (2048) pixels
0x0000, 0x0000, 0x0000, 0xFA8A, 0xF9E7, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0810 (2064) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0820 (2080) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0830 (2096) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF945, 0xFA49, 0xFAEB, 0x0000, 0x0000, 0x0000,   // 0x0840 (2112) pixels
0x0000, 0x0000, 0x0000, 0xFA8A, 0xFA28, 0xF965, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0850 (2128) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0860 (2144) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0870 (2160) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8E3, 0xF9E7, 0xFAEB, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0880 (2176) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0xF9E7, 0xF9C7, 0xF904, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0890 (2192) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x08A0 (2208) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x08B0 (2224) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF882, 0xF986, 0xFACB, 0xFBCF, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x08C0 (2240) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA08, 0xF986, 0xF8A2, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x08D0 (2256) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x08E0 (2272) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x08F0 (2288) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF945, 0xFA69, 0xFACB, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0900 (2304) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA28, 0xF965, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0910 (2320) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0920 (2336) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0930 (2352) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF904, 0xFA49, 0xFAAA, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0940 (2368) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFB2C, 0xFA69, 0xF924, 0xF861, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0950 (2384) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0960 (2400) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0970 (2416) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF8C3, 0xFA28, 0xFA8A, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0980 (2432) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFAEB, 0xFA28, 0xF924, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0990 (2448) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x09A0 (2464) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x09B0 (2480) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF8C3, 0xF9C7, 0xFA49, 0xFA8A, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x09C0 (2496) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFACB, 0xF9A6, 0xF924, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x09D0 (2512) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x09E0 (2528) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x09F0 (2544) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xF9C7, 0xFA49, 0xFA69, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0A00 (2560) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFACB, 0xF9A6, 0xF904, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0A10 (2576) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0A20 (2592) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0A30 (2608) pixels
0xF800, 0xF800, 0xF800, 0xF8C3, 0xF965, 0xFA8A, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0A40 (2624) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFB2C, 0xF965, 0xF8E3, 0xF841, 0xF800, 0xF800,   // 0x0A50 (2640) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0A60 (2656) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0A70 (2672) pixels
0xF800, 0xF800, 0xF8E3, 0xF965, 0xFA8A, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0A80 (2688) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA08, 0xF9C7, 0xF8E3, 0xF861, 0xF800,   // 0x0A90 (2704) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0AA0 (2720) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0AB0 (2736) pixels
0xF800, 0xF8C3, 0xF986, 0xFAEB, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0AC0 (2752) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA28, 0xFA08, 0xF904, 0xF841,   // 0x0AD0 (2768) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0AE0 (2784) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820,   // 0x0AF0 (2800) pixels
0xF8A2, 0xF9A6, 0xFB2C, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0B00 (2816) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA49, 0xFA08, 0xF904,   // 0x0B10 (2832) pixels
0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0B20 (2848) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF8A2,   // 0x0B30 (2864) pixels
0xF9C7, 0xF9E7, 0xFB6D, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0B40 (2880) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA69, 0xF9A6,   // 0x0B50 (2896) pixels
0xF945, 0xF820, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0B60 (2912) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF8E3, 0xF9C7,   // 0x0B70 (2928) pixels
0xFA08, 0xFA49, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0B80 (2944) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFACB,   // 0x0B90 (2960) pixels
0xF986, 0xF965, 0xF861, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0BA0 (2976) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF904, 0xF9C7, 0xFA8A,   // 0x0BB0 (2992) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0BC0 (3008) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0BD0 (3024) pixels
0xFB2C, 0xF9E7, 0xF924, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0BE0 (3040) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF904, 0xF986, 0xFB2C, 0x0000,   // 0x0BF0 (3056) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C00 (3072) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C10 (3088) pixels
0x0000, 0xFA69, 0xF9E7, 0xF924, 0xF8A2, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0C20 (3104) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF8E3, 0xF986, 0xFB0C, 0x0000, 0x0000,   // 0x0C30 (3120) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C40 (3136) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C50 (3152) pixels
0x0000, 0x0000, 0xFAAA, 0xFA28, 0xF945, 0xF882, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0C60 (3168) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF841, 0xF8E3, 0xF9C7, 0xFA08, 0x0000, 0x0000, 0x0000,   // 0x0C70 (3184) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C80 (3200) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0C90 (3216) pixels
0x0000, 0x0000, 0x0000, 0xFACB, 0xFA49, 0xF965, 0xF861, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0CA0 (3232) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF8C3, 0xFA08, 0xFA28, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CB0 (3248) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CC0 (3264) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CD0 (3280) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0xFAEB, 0xFA08, 0xF986, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0CE0 (3296) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF8C3, 0xF9E7, 0xFA49, 0xFA69, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0CF0 (3312) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D00 (3328) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D10 (3344) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFB6D, 0xF9C7, 0xF986, 0xF861, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0D20 (3360) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF820, 0xF904, 0xF986, 0xFA8A, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D30 (3376) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D40 (3392) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D50 (3408) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFACB, 0xFA08, 0xF924, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0D60 (3424) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8E3, 0xF9C7, 0xFA8A, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D70 (3440) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D80 (3456) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0D90 (3472) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA08, 0xF9E7, 0xF924, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0DA0 (3488) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF800, 0xF8C3, 0xF986, 0xFB4D, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0DB0 (3504) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0DC0 (3520) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0DD0 (3536) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA8A, 0xFA28, 0xF904, 0xF841, 0xF800, 0xF800, 0xF800, 0xF800,   // 0x0DE0 (3552) pixels
0xF800, 0xF800, 0xF800, 0xF800, 0xF8A2, 0xF965, 0xFB0C, 0xFC71, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0DF0 (3568) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E00 (3584) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E10 (3600) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA49, 0xFA08, 0xF8C3, 0xF820, 0xF800, 0xF800, 0xF800,   // 0x0E20 (3616) pixels
0xF800, 0xF800, 0xF800, 0xF861, 0xF965, 0xFAAA, 0xFB8E, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E30 (3632) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E40 (3648) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E50 (3664) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA28, 0xF9C7, 0xF882, 0xF800, 0xF800, 0xF800,   // 0x0E60 (3680) pixels
0xF800, 0xF800, 0xF820, 0xF8E3, 0xFA08, 0xFAEB, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E70 (3696) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E80 (3712) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0E90 (3728) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA28, 0xF9E7, 0xF965, 0xF841, 0xF800, 0xF800,   // 0x0EA0 (3744) pixels
0xF800, 0xF800, 0xF8C3, 0xF9C7, 0xFA8A, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0EB0 (3760) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0EC0 (3776) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0ED0 (3792) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xF9E7, 0xF9C7, 0xF945, 0xF820, 0xF800,   // 0x0EE0 (3808) pixels
0xF800, 0xF861, 0xF986, 0xFA69, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0EF0 (3824) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0F00 (3840) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0F10 (3856) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA28, 0xF9C7, 0xF8E3, 0xF800,   // 0x0F20 (3872) pixels
0xF820, 0xF945, 0xFA28, 0xFA69, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0F30 (3888) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0F40 (3904) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0F50 (3920) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFA28, 0xF986, 0xF8A2,   // 0x0F60 (3936) pixels
0xF8C3, 0xFA08, 0xFA49, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0F70 (3952) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0F80 (3968) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0F90 (3984) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFB2C, 0xFA28, 0xF945,   // 0x0FA0 (4000) pixels
0xF9A6, 0xF9C7, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0FB0 (4016) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0FC0 (4032) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0FD0 (4048) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0xFAAA, 0xFAAA,   // 0x0FE0 (4064) pixels
0xFB4D, 0xFB6D, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x0FF0 (4080) pixels
0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000,   // 0x1000 (4096) pixels
    matrix->begin();
    matrix->show();
    delay(2000);
    matrix->clear();
matrix->drawRGBBitmap(0, 0, heart, 64, 64);
matrix->show();
The problem was solved ONLY when instead of using LVGL image converter I used the ImageConverter (UTFT) from Rinky Dinky Electronics
http://rinkydinkelectronics.com/t_imageconverter565.php
Since it seems to me that this converter uses 565 RGB coding I do not understand while the same option from LVGL converter is not working but I'm such a newbie of this fied that the explanation may be is obvious.
One more remark: I perfectly agree with your observation after having tried several different images
The last obstacle for me now is to learn how to resize an image so that I can use the display for the image and a line of text. Is it correct to scale the image to a smaller dimension (eg 32x32) before converting it to an array or have I to use a different approach? Thanks again for your help and have a nice day
