Unable to start using Arduino
Recently acquired an old unopened Starter Kit from a few years ago to mess with and having issues getting connected to it.
I have been unable to upload BLINK into the UNO and received the following output
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Tibbers\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x72
I have confirmed that the correct board is selected and tried both 1.8.3 and 1.6.2 for the board manager. I have tried to burn the bootloader and received the following:
Arduino: 1.8.13 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Tibbers\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\Tibbers\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM1 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
Using Port : COM1
Using Programmer : stk500v1
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
Tried the reset button on the board, which causes the L light to blink very rapidly 3 times, followed by a quick 3 blinks, followed by a quick 2 blinks. Following this the L light blinks on and off regularly and slowly.
Not sure how best to proceed, should I go back farther on the board versioning or is the board not working due to its age?
The error is showing it’s trying to connect over com port 1 . Your Arduino won’t be connected to that - look under tools/ports to find the correct port.
If the port is not there, and if you starter kit is not genuine Arduino it may need a specific driver install . CH340 ?
Take a look at the trouble shooting guide ....
