Here's the fullcode and the breadboard wiring scheme
#include <ESP8266HTTPClient.h>
#include <ESP8266WiFi.h>
#include <DHT.h>
//setting variable sensor
#define DHTTYPE DHT11
#define DHTPIN 10 // NodeMCU pin SD3/GPIO 10 konek ke DHT-11 Signal pin
DHT dht(DHTPIN, DHTTYPE);
// Keep this API Key value to be compatible with the PHP code provided in the project page.
// If you change the apiKeyValue value, the PHP file /esp-post-data.php also needs to have the same key
String apiKeyValue = "tPmAT5Ab3j7F9";
String sensorName = "DHT11";
String sensorLocation = "Office";
//setting jaringan
const char ssid[] = "Pratama";
const char pass[] = "123454321";
const char servername[] = "http://172.20.10.2/skripsi/esp-post-data.php";
WiFiClient client;
float Val,Val1 ; // Inisialilasasi Input
float m_suhu, m_jarak; // Inisialilasasi Derajat Keanggotaan
float dingin, hangat, panas; // Inisialilasasi Membership Function suhu
float dekat, sedang, jauh; // Inisialilasasi Membership Function jarak
float dingin_1, hangat_1, panas_1; // Inisialilasasi Membership yang aktif
float dekat_1, sedang_1, jauh_1; // Inisialilasasi Membership yang aktif
float Lmax=0, Mmax=0, Hmax=0; // Inisialilasasi Defuzzification
float fsmax=0; // Inisialilasasi nilai maksimum
float num, den, output; //Inisialilasasi defuzzification
int device1_pin = 12; // NodeMCU pin D6/GPIO12 konek ke relay 1
int device2_pin = 14; // NodeMCU pin D5/GPIO14 konek ke relay 2
int device_status1; // Relay 1 status
int device_status2; // Relay 2 status
unsigned int EchoPin = 13; // NodeMCU pin D7/GPIO13 konek ke US-100 echo/RX
unsigned int TrigPin = 15; // NodeMCU pin D8/GPIO15 konek ke US-100 Trig / TX
unsigned long Time_Echo_us = 0;
//unsigned long jaraksensor = 0;
float jaraksensor;
float suhusensor;
float suhumanual;
float jarakmanual;
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastTime = 0;
// Timer set to 10 minutes (600000)
//unsigned long timerDelay = 600000;
// Set timer to 30 seconds (30000)
unsigned long timerDelay = 30000;
// ------------------------------------------------- Fuzzification ------------------------------------------------------------
pinMode(LED_BUILTIN, OUTPUT);
pinMode(device1_pin, OUTPUT);
pinMode(device2_pin, OUTPUT);
pinMode(EchoPin, INPUT); // The set EchoPin input mode.
pinMode(TrigPin, OUTPUT); // The set TrigPin output mode.
dht.begin();
//setting koneksi wifi
WiFi.hostname("NodeMCU");
WiFi.persistent(false);
WiFi.begin(ssid, pass);
//cek koneksi WiFi
while(WiFi.status() != WL_CONNECTED)
//nodemcu terus mencoba koneksi
digitalWrite(LED_BUILTIN, HIGH);
Serial.println("PROTOTIPE MONITORING SUHU DAN SENSOR GERAK");
Serial.println(".");
//apabila berhasil terkoneksi
digitalWrite(LED_BUILTIN, LOW);
Serial.println("WiFi Connected");
//memulai server
Serial.println("Server started");
Serial.print(WiFi.localIP());
Serial.println("connecting...");
void suhu()
suhusensor = dht.readTemperature();
suhumanual = 38;
void jarak()
digitalWrite(TrigPin, HIGH); // Send pulses begin by Trig / Pin
delayMicroseconds(50); // Set the pulse width of 50us (> 10us)
digitalWrite(TrigPin, LOW); // The end of the pulse
Time_Echo_us = pulseIn(EchoPin, HIGH); // A pulse width calculating US-100 returned
if((Time_Echo_us < 60000) && (Time_Echo_us > 1))
// Pulse effective range (1, 60000).
// jaraksensor = (Time_Echo_us * 0.34mm/us) / 2 (mm)
jaraksensor = (Time_Echo_us*34/100)/2; // Calculating the distance by a pulse width.
jarakmanual = 400 ;
void relay() {
if(device_status1 == 1)
digitalWrite(device1_pin,LOW);
Serial.println("Relay 1 ON");
Serial.print("Relay (Tombol) 1 Status=");
Serial.println(device_status1); //Print the response payload
if(device_status2 == 1)
digitalWrite(device2_pin,LOW);
Serial.println("Relay 2 ON");
Serial.print("Relay (Tombol) 2 Status=");
Serial.println(device_status2); //Print the response payload
fuzzy();
Serial.println("----------------------------------------------------");
void fuzzy()
// ----------------------------------------- Membership Function ---------------------------------------------
//SUHU DAN JARAK MENGGUNAKAN INPUT MANUAL
if(suhumanual <= 25)
dingin=1;
hangat=0;
panas=0;
else if(suhumanual >= 35)
panas=1;
dingin=0;
hangat=0;
else if(suhumanual == 30)
hangat=1;
dingin=0;
panas=0;
else if((suhumanual > 25)&&(suhumanual <30))
hangat = (suhumanual-25)/5;
dingin = 1-(suhumanual-25)/5;
panas = 0;
else if((suhumanual > 30)&&(suhumanual < 35))
panas = (suhumanual-30)/5;
hangat = 1-(suhumanual-30)/5;
dingin = 0;
if(jarakmanual<150)
dekat = 1;
sedang = 0;
jauh = 0;
else if(jarakmanual >= 350)
jauh = 1;
dekat = 0;
sedang = 0;
else if(jarakmanual == 250)
sedang = 1;
dekat = 0;
jauh = 0;
else if((jarakmanual > 150)&&(jarakmanual < 250))
sedang = (jarakmanual-150)/100;
dekat = 1-(jarakmanual-150)/100;
jauh = 0;
else if((jarakmanual > 250)&&(jarakmanual < 350))
jauh = (jarakmanual-250)/100;
sedang = 1-(jarakmanual-250)/100;
dekat = 0;
//SUHU DAN JARAK MENGGUNAKAN INPUT DARI SENSOR
if(suhusensor <= 25)
dingin=1;
hangat=0;
panas=0;
else if(suhusensor >= 35)
panas=1;
dingin=0;
hangat=0;
else if(suhusensor == 30)
hangat=1;
dingin=0;
panas=0;
else if((suhusensor > 25)&&(suhusensor <30))
hangat = (suhusensor-25)/5;
dingin = 1-(suhusensor-25)/5;
panas = 0;
else if((suhusensor > 30)&&(suhusensor < 35))
panas = (suhusensor-30)/5;
hangat = 1-(suhusensor-30)/5;
dingin = 0;
dekat = 1;
sedang = 0;
jauh = 0;
else if(jaraksensor >= 350)
jauh = 1;
dekat = 0;
sedang = 0;
else if(jaraksensor == 250)
sedang = 1;
dekat = 0;
jauh = 0;
else if((jaraksensor > 150)&&(jaraksensor < 250))
sedang = (jaraksensor-150)/100;
dekat = 1-(jaraksensor-150)/100;
jauh = 0;
else if((jaraksensor > 250)&&(jaraksensor < 350))
jauh = (jaraksensor-250)/100;
sedang = 1-(jaraksensor-250)/100;
dekat = 0;
// ----------------------------------------- Mechanism Inference ----------------------------------------
if (dingin >0)
dingin_1 = 1;
dingin_1 = 0;
if (hangat >0)
hangat_1 = 1;
hangat_1 = 0;
if (panas >0)
panas_1 = 1;
panas_1 = 0;
if (dekat >0)
dekat_1 = 1;
dekat_1 = 0;
if (sedang >0)
sedang_1 = 1;
sedang_1 = 0;
if (jauh >0)
jauh_1 = 1;
jauh_1 = 0;
float L[4]={0,1,2,3}; // Low output, relay mati keduanya
if (dingin_1==1 && dekat_1==1) {L[1]=min(dingin,dekat);} else {L[1]=0;}
if (dingin_1==1 && sedang_1==1) {L[2]=min(dingin,sedang);} else {L[2]=0;}
if (dingin_1==1 && jauh_1==1) {L[3]=min(dingin,jauh);} else {L[3]=0;}
float M[6]={0,1,2,3,4,5}; // Medium output, 1 relay aktif
if (hangat_1==1 && dekat_1==1) {M[1]=min(hangat,dekat);} else {M[1]=0;}
if (hangat_1==1 && sedang_1==1) {M[2]=min(hangat,sedang);} else {M[2]=0;}
if (hangat_1==1 && jauh_1==1) {M[3]=min(hangat,jauh);} else {M[3]=0;}
if (panas_1==1 && dekat_1==1) {M[4]=min(panas,dekat);} else {M[4]=0;}
if (panas_1==1 && sedang_1==1) {M[5]=min(panas,sedang);} else {M[5]=0;}
float H[2]={0,1}; // High output, 2 relay aktif
if (panas_1==1 && jauh_1==1) {H[1]=min(panas,jauh);} else {H[1]=0;}
Lmax=L[0]; int index1=0; for (int a=1; a<=3; a++) { if(Lmax<=L[a]) { Lmax=L[a]; index1=a;} }
Mmax=M[0]; int index2=0; for (int b=1; b<=5; b++) { if(Mmax<=M[b]) { Mmax=M[b]; index2=b;} }
Hmax=H[0]; int index3=0; for (int c=1; c<=1; c++) { if(Hmax<=H[c]) { Hmax=H[c]; index3=c;} }
// --------------------------------------------------------------------------- End Interface Mechanism ----------------------------------------------------------------
// --------------------------------------------------------------------------- Defuzzyfication -----------------------------------------------------------------------//
float num = (Lmax*0) + (Mmax*50) + (Hmax*100);
float den = Lmax + Mmax + Hmax;
float output = num/den;
if(output < 50) {
digitalWrite(device1_pin, HIGH);
Serial.print("relay 1: MATI");
Serial.println(" ");
digitalWrite(device2_pin, HIGH);
Serial.print("relay 2: MATI");
else if(output >= 50 && output <=80) {
digitalWrite(device1_pin, LOW);
Serial.print("relay 1: HIDUP");
else {
digitalWrite(device2_pin, LOW);
Serial.print("relay 2: HIDUP");
//Hasil print
Serial.print("suhu (dari sensor): ");
Serial.println(suhusensor);
Serial.print("suhu (manual): ");
Serial.println(suhumanual);
Serial.print("jarak (dari sensor): "); // Output to the serial port monitor
Serial.print(jaraksensor, DEC); // Output to the serial port monitor
Serial.println("mm"); // Output to the serial port monitor
Serial.print("jarak (manual): "); // Output to the serial port monitor
Serial.print(jarakmanual); // Output to the serial port monitor
Serial.print("dingin : ");
Serial.println(dingin);
Serial.print("hangat : ");
Serial.println(hangat);
Serial.print("panas : ");
Serial.println(panas);
Serial.print("dekat : ");
Serial.println(dekat);
Serial.print("sedang : ");
Serial.println(sedang);
Serial.print("jauh : ");
Serial.println(jauh);
Serial.print("m_suhu : ");
Serial.println(m_suhu);
Serial.print("m_jarak : ");
Serial.println(m_jarak);
Serial.print("L 0 : ");
Serial.println(L[0]);
Serial.print("L 1 : ");
Serial.println(L[1]);
Serial.print("L 2 : ");
Serial.println(L[2]);
Serial.print("L 3 : ");
Serial.println(L[3]);
Serial.print("M 0 : ");
Serial.println(M[0]);
Serial.print("M 1 : ");
Serial.println(M[1]);
Serial.print("M 2 : ");
Serial.println(M[2]);
Serial.print("M 3 : ");
Serial.println(M[3]);
Serial.print("M 4 : ");
Serial.println(M[4]);
Serial.print("M 5 : ");
Serial.println(M[5]);
Serial.print("H 0 : ");
Serial.println(H[0]);
Serial.print("H 1 : ");
Serial.println(H[1]);
Serial.print("num : ");
Serial.println(num);
Serial.print("den : ");
Serial.println(den);
Serial.print("output : ");
Serial.println(output);
void httppost()
//Send an HTTP POST request every 10 minutes
if ((millis() - lastTime) > timerDelay) {
//Check WiFi connection status
if(WiFi.status()== WL_CONNECTED){
WiFiClient client;
HTTPClient http;
// Your Domain name with URL path or IP address with path
http.begin(client, servername);
// Specify content-type header
http.addHeader("Content-Type", "application/x-www-form-urlencoded");
// Prepare your HTTP POST request data
String httpRequestData = "api_key=" + apiKeyValue + "&sensor=" + sensorName
+ "&location=" + sensorLocation + "&value1=" + String(dht.readTemperature())
+ "&value2=" + String(dht.readHumidity()) + "&value3=" + jaraksensor + "";
//Serial.print("httpRequestData: ");
//Serial.println(httpRequestData);
// You can comment the httpRequestData variable above
// then, use the httpRequestData variable below (for testing purposes without the BME280 sensor)
//String httpRequestData = "api_key=tPmAT5Ab3j7F9&sensor=BME280&location=Office&value1=24.75&value2=49.54&value3=1005.14";
// Send HTTP POST request
int httpResponseCode = http.POST(httpRequestData);
// If you need an HTTP request with a content type: text/plain
//http.addHeader("Content-Type", "text/plain");
//int httpResponseCode = http.POST("Hello, World!");
// If you need an HTTP request with a content type: application/json, use the following:
//http.addHeader("Content-Type", "application/json");
//int httpResponseCode = http.POST("{\"value1\":\"19\",\"value2\":\"67\",\"value3\":\"78\"}");
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
else {
Serial.print("Error code: ");
// Free resources
http.end();
suhu();
jarak();
httppost();
relay();
//Serial.println("IP address: ");
//Serial.println(WiFi.localIP());
delay(10000);
