Unable to upload anything to cloned Nano
I have a cloned Nano board which is working (I bought it with code already on it and have been using it for a while. I now want to change the code.)
It has a ATMEL mega328P chip. I am connected via a FTDI232 USB interface.
I have the same problem on my mac (OSX 10.15.3 + Arduino IDE 1.8.12) and also on my Windows laptop (Windows 10 + Adruino IDE 1.8.12), although slighty different error codes.
In Windows, the IDE sees the board on COM3, but shows "unknown board" in get board info.
On Mac, the IDE sees the board on \dev\usb-00000000 (which seems strange)
I have checked the settings in IDE for board, processer, port, and programmer. I've updated the FTDI drivers as well.
When I try to upload anything I get the error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2b
Any help would be appreciated!
Thanks!
grahamjtr:
This is normal and expected. The reason is because the Nano (official, clones, and derivatives) use a general purpose USB to serial adapter chip, which doesn't allow the Arduino IDE to identify which specific board is attached (because that adapter chip could be used on any board).
grahamjtr:
It will be helpful if you provide the full output:
Please do this:
  1. When you encounter an error, you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  2. Open a forum reply here by clicking the Reply button.
  3. Click the </> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  4. Press Ctrl+V. This will paste the compilation output into the code block.
  5. Move the cursor outside of the code block markup before you add any additional text to your reply.
  6. Click the Reply button to post the output.
grahamjtr:
A bit unclear, you do not connect a Nano via an FTDI232 interface, a Nano has an onboard USB interface. The onboard interface can be an FTDI232, but most clones use something cheaper like a CH340.
If the board came with code already installed, it may not have the bootloader installed. Can you post a link to where you purchased the board?
