Unable to upload firmata on Arduino Yun
I'm trying to upload StandardFirmata sketch on Arduino Yun.
I'm following the tips in this thread Tty for serial port to Arduino from Linino - Arduino Yún - Arduino Forum
  1. The serial console is disabled in /etc/inittab.
  2. I've added the following lines in the setup function:
    Serial1.begin(9600); // Set the baud.
  • Firmata.begin(Serial1);*
  1. I'm using Arduino IDE 1.5.5-r2.
The errors that I'm getting:
Arduino: 1.5.5-r2 (Windows 8), Board: "Arduino Yún"
StandardFirmata:26: error: redefinition of 'int analogInputsToReport'
StandardFirmata:54: error: 'int analogInputsToReport' previously defined here
StandardFirmata:29: error: redefinition of 'byte reportPINs [4]'
StandardFirmata:57: error: 'byte reportPINs [4]' previously declared here
StandardFirmata:30: error: redefinition of 'byte previousPINs [4]'
StandardFirmata:58: error: 'byte previousPINs [4]' previously declared here
StandardFirmata:33: error: redefinition of 'byte pinConfig [30]'
StandardFirmata:61: error: 'byte pinConfig [30]' previously declared here
StandardFirmata:34: error: redefinition of 'byte portConfigInputs [4]'
StandardFirmata:62: error: 'byte portConfigInputs [4]' previously declared here
StandardFirmata:35: error: redefinition of 'int pinState [30]'
StandardFirmata:63: error: 'int pinState [30]' previously declared here
StandardFirmata:38: error: redefinition of 'long unsigned int currentMillis'
StandardFirmata:66: error: 'long unsigned int currentMillis' previously declared here
StandardFirmata:39: error: redefinition of 'long unsigned int previousMillis'
StandardFirmata:67: error: 'long unsigned int previousMillis' previously declared here
StandardFirmata:40: error: redefinition of 'int samplingInterval'
StandardFirmata:68: error: 'int samplingInterval' previously defined here
StandardFirmata:42: error: redefinition of 'Servo servos [12]'
StandardFirmata:85: error: 'Servo servos [12]' previously declared here
StandardFirmata.pde: In function 'void outputPort(byte, byte, byte)':
StandardFirmata:48: error: redefinition of 'void outputPort(byte, byte, byte)'
StandardFirmata:137: error: 'void outputPort(byte, byte, byte)' previously defined here
StandardFirmata.pde: In function 'void checkDigitalInputs()':
StandardFirmata:62: error: redefinition of 'void checkDigitalInputs()'
StandardFirmata:151: error: 'void checkDigitalInputs()' previously defined here
StandardFirmata.pde: In function 'void setPinModeCallback(byte, int)':
StandardFirmata:89: error: redefinition of 'void setPinModeCallback(byte, int)'
StandardFirmata:178: error: 'void setPinModeCallback(byte, int)' previously defined here
StandardFirmata.pde: In function 'void analogWriteCallback(byte, int)':
StandardFirmata:156: error: redefinition of 'void analogWriteCallback(byte, int)'
StandardFirmata:251: error: 'void analogWriteCallback(byte, int)' previously defined here
StandardFirmata.pde: In function 'void digitalWriteCallback(byte, int)':
StandardFirmata:174: error: redefinition of 'void digitalWriteCallback(byte, int)'
StandardFirmata:269: error: 'void digitalWriteCallback(byte, int)' previously defined here
StandardFirmata.pde: In function 'void reportAnalogCallback(byte, int)':
StandardFirmata:204: error: redefinition of 'void reportAnalogCallback(byte, int)'
StandardFirmata:299: error: 'void reportAnalogCallback(byte, int)' previously defined here
StandardFirmata.pde: In function 'void reportDigitalCallback(byte, int)':
StandardFirmata:216: error: redefinition of 'void reportDigitalCallback(byte, int)'
StandardFirmata:311: error: 'void reportDigitalCallback(byte, int)' previously defined here
StandardFirmata.pde: In function 'void sysexCallback(byte, byte, byte*)':
StandardFirmata:233: error: redefinition of 'void sysexCallback(byte, byte, byte*)'
StandardFirmata:328: error: 'void sysexCallback(byte, byte, byte*)' previously defined here
StandardFirmata.pde: In function 'void setup()':
StandardFirmata:322: error: redefinition of 'void setup()'
StandardFirmata:585: error: 'void setup()' previously defined here
StandardFirmata.pde: In function 'void loop()':
StandardFirmata:368: error: redefinition of 'void loop()'
StandardFirmata:604: error: 'void loop()' previously defined here
It seems that the problem is related to the newest version of the Arduino IDE.
With IDE 1.5.4 everything works fine.
