unable to upload programs on mac osx 10.9.2
I've been using the arduino compiler for my PC xp system. I just installed it on my iMac
I've tried to select every port that comes up under tools, but I still don't have any communication to my board. I keep getting the avrdude stk500 error. I'm using the Arduino duemilanove
Any suggestions?
EDIT: I have found some other threads suggesting that there is an issue with the USB drivers for Mavericks which I had previously installed.
problem solved
installed drivers
Hello,
I am having a very similar problem. Could you please explain how exactly you resolved the issue? Or point me in the direction of the other threads that helped you out?
Thanks.
Go here
http://www.ftdichip.com/Drivers/VCP.htm
I downloaded the driver for the mac
I had to modify the imac security to allow the program to install the drivers.
Make sure you have a time machine backup of everything in case there is a problem.
This fixed it.
I am having trouble downloading programs on MACs. Could you please help?
Hi there from New Zealand.
I too am a newcomer to the Arduino - just got my kit yesterday.
I tried to download the latest software and it would not run on my older mac - OSX 10.5.8
So I downloaded Arduiino 1.0.6 from the "older" software on the downloads page.
This works.
I had to plug in the UNO to the usb slot on my mac
Then Start Arduino
Then went to the menu-bar and choose Tools / Serial Port / dev/cu.usbmodem2b1211
After that I was able to open the "Blink" Script, Verify, then Upload .
Success 100%
I hope this helps you get up and running.
Good fortune with the kit.
Sandy
New Zealand
