Unable to upload sketch to my arduino nano
Sketch uses 1894 bytes (6%) of program storage space. Maximum is 30720 bytes.
Global variables use 59 bytes (2%) of dynamic memory, leaving 1989 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\KESH\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\KESH\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM5" -b115200 -D "-Uflash:w:C:\Users\KESH\AppData\Local\Temp\arduino-sketch-001B2F003210E3093BD829E3F79B59B6/sketch_mar16a.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\KESH\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM5
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6f
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
  • Check your USB cable. You need so called "data-cable". The charging-only cables won't work.
  • Try to select "Old bootloader" option in the IDE-Tools menu.
I've changed the cable and this time around i am sure it's a data cable.
i have also selected "old bootloader" but still having the same error
Is COM5 indeed the Nano? Does it disappear from the IDE ports selection if you disconnect the board?
Did upload to the board ever work? Or is this the first time that you use the board?
We don't know which board you exactly have. Some cheap Chinese crap sometimes ships with the 168 so you can try that processor option as well if you did not buy a genuine Arduino.
This is the first time i am using the board
