Unable to upload sketch
Hello,
Using Arduino IDE, version 2.1.1 on MacOS 12.6.3
Trying to upload sketch, get a number of
avrdude: jtagmkII_getsync(): sign-on command: status -1
messages, then fails.
I have followed the suggestions here: https://support.arduino.cc/hc/en-us/articles/4401874331410--Error-avrdude-when-uploading, verified I have correct board, port etc, but to no avail, as well as suggestions on other threads.
I tried 2 different boards, have uploaded to these boards in the past, though possible on an earlier version of Arduino IDE.
I am able to get board info, so it appears the IDE is connecting to the board and recognizing it.
Follows are verbose output, and screenshots:
Sketch uses 1118 bytes (2%) of program storage space. Maximum is 49152 bytes.
Global variables use 22 bytes (0%) of dynamic memory, leaving 6122 bytes for local variables. Maximum is 6144 bytes.
Performing 1200-bps touch reset on serial port /dev/cu.usbmodem14101
"/Users/kevin/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/kevin/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega4809 -cjtag2updi -P/dev/cu.usbmodem14101  -b115200 -e -D "-Uflash:w:/private/var/folders/kn/4qz43m013z55h7c52hytb9gc0000gn/T/arduino/sketches/45771D317A4BE267E7777F68DF1202AE/Blink.ino.hex:i" "-Ufuse2:w:0x01:m" "-Ufuse5:w:0xC9:m" "-Ufuse8:w:0x00:m" {upload.extra_files}
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/kevin/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/Users/kevin/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem14101
         Using Programmer              : jtag2updi
         Overriding Baud Rate          : 115200
avrdude: jtagmkII_getsync(): timeout/error communicating with programmer (status -1)
avrdude done.  Thank you.
Failed uploading: uploading error: exit status 1
port_selection
board_info
Well, after trying different boards, fiddling with port designations and rebooting my computer, everything seems to be working now, though as I did a shotgun approach, I'm not really sure which did the trick.
