I am new to arduino, i am trying to upload a sketch and getting following error.
open nul: the system cannot find the file specified.
error compiling for board arduino/genuino uno.
OS: Windows 10
Arduino Ide : 1.8.5
Please help
OS: Windows 10
Arduino Ide : 1.8.5
Please help
Please take a few moments to Learn and Use The Forum
How to get the best out of this forum Installation & Troubleshooting
Hello, Welcome to the Arduino Forum. This guide explains how to get the best out of this forum. Please read and follow the instructions below. Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us. The people who try to help with your pro…
It will help you get the very best out of the forum in the future.
COMMON ISSUES
COMPUTER RELATED
ARDUINO SPECIFIC BOARDS
CREATE editor install locations.
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Also make sure you are not using a USB 3.0 port and that you have selected the correct COM port as listed in windows device manager for the board (you failed to mention type).
I have some problem while uploading arduinoisp to new atmega328P-PU it shows invalid library and bootloader while click this message shows...
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
Error while burning bootloader.
Hello!,
If you want, try out this post, Error conpiling to Arduino Uno-SOLVED!
Hi... I am also new to Arduino and I can't seem to upload a sketch. Any help would be greatly appreciated.
Arduino: 1.6.11 (Windows 8.1), Board: "Intel® Edison"
Sketch uses 76,331 bytes (0%) of program storage space. Maximum is 10,000,000 bytes.
C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin/bash.exe --verbose --noprofile C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\Kevin\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp/Blink.ino.elf COM5
#!/bin/sh
echo "starting download script"
echo "Args to shell:" $*
#path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\//}
#COM ports are not always setup to be addressed via COM for redirect.
#/dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadEdison" > $tty_port_id
Args to shell: C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\Kevin\AppData\Local\Temp\build08e4957f02c018eb579e11ddc64f9701.tmp/Blink.ino.elf COM5
COM PORT 5
Converted COM Port COM5 to tty port /dev/ttyS4
C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 42: /dev/ttyS4: Permission denied
Deleting existing sketch on target
#Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 46: /dev/ttyS4: Permission denied
#Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 51: /dev/ttyS4: Permission denied
#mv the downloaded file to /sketch/sketch.elf
target_download_name="${host_file_name##*/}"
Moving downloaded file to /sketch/sketch.elf on target
echo "Moving downloaded file to /sketch/sketch.elf on target"
"$fixed_path/lsz.exe" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" <> $tty_port_id 1>&0
C:\Users\Kevin\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/clupload/cluploadEdison_win.sh: line 56: /dev/ttyS4: Permission denied
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Are you certain your Edison board is on COM5?
Try this:
If the COM5 port is correct, try restarting your computer. Sometimes COM ports can get stuck and cause this sort of problem.
