Hi there,
I just got an Arduino M0 and I'm stuck at uploading the blink sketch to the board.
Board:
Genuine Arduino M0
(not Pro, not Zero, just M0 marked on Silkscreen, only one USB port present)
Play-Zone.ch
Arduino IDE: 1.6.9
OS: Windows 10
Board is recognized under device manager (COM & LPT)
"Arduino Zero Native Port (COM4)"
Setup:
Board: "Arduino/Genuino Zero (Native USB Port)"
Port: "COM4"
Programmer: "USBtinyISP" also tried "USBasp" / "Atmel SAM-ICE" and so on. All with same result.
Problem:
When hitting the upload button, it compiles.
Then the Windows disconnect sound comes up, the Arduino IDE throws a "No device found on COM5" error. Status keeps reading "Uploading...". A few seconds later, the Windows device connect sound comes up.
In Tools > Port, no Port is selected afterwards. The board is available on COM4.
To me it looks like the board gets disconnected at reset and isn't reconnected soon enough for the IDE to see the board on the correct port. (Similar to the Leonardo)
Also tried a different (shorter) USB cable and different USB ports, same results.
Console Output:
Sketch uses 8,356 bytes (3%) of program storage space. Maximum is 262,144 bytes.
Does anyone have any hints for what this could be?
