Hey Guys,
I have a problem with a FREEDUINO ( Arduino Compatible Board), The Atmega 328 seems fine .
- Tried programming the ATMega chip with another Arduino board, Worked like charm.
When I put the same chip again in the FREEDUINO Board.
The program Runs Fine I am able to use all inputs and outputs.
The only fault is, I am unable to program with the freeduino.
My Suspect is the USB to UART Bridge ( CP2102 Silicon Labs Chip ) has gone bad.
Data sheet: https://goo.gl/XLhHhr
I Don't know how to test it.
Ohh, By the Way, There are serial inputs in this board
Named (MISO,5V,SCK,MOSI,RST,GND)
I have bought USB TO TTL UART Bridge based on same CP2102 Chip can I use them
