Unable to upload to my arduino uno smd r2
This is the first time I hooked up my arduino and after installing the driver and checking the port it is connected to I loaded the example file "blink".
When i tried to upload the file it gives the following error:
Binary sketch size: 1018 bytes (of a 32256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
The I have is: arduino uno smd r2
The OS: windows 7 (32bit)
I already tried a some of the things disgust on the forum:
  • pushing the reset button just before uploading.
  • Installing the driver for windows using the device manager.
  • Then is set the serial port in the program to com3 and selected the board arduino uno.
    This didn't do it.
  • The ten I saw something about when you push the reset button and a led has to blink.
    This is not happening in my case, and should be a problem with the boot loader. Is this true, and which one do I have to install?
Hope someone can help me
Gr
Erik
I also have the same UNO board (SMD R2) and had this issue.
I moved the device to a different USB port and it then worked. My resolution may have been for a different problem (I have two UNOs) but you should try it (if not already done).
Search for USBDview (Google), and examine its output for clues as well.
