Unable to upload to Sparkfun RedBot Mainboard
Hi
I am just trying to upload (from a mac) a basic blink test to the Sparkfun RedBot but I keep getting this error:
Binary sketch size: 1,076 bytes (of a 32,256 byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P/dev/tty.usbserial-A6026LQW -b115200 -D -Uflash:w:/var/folders/jt/mpqf6pmx6kd8k1q7cvlmnwnw0000gn/T/build1177920591307596948.tmp/sketch_dec27a.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/bob/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/tty.usbserial-A6026LQW
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: ser_recv(): programmer is not responding
avrdude done.  Thank you.
The board has power and I have tried it with nothing plugged in but it won't upload (except battery and usb). I have tried looking around on the internet but no solutions have worked for me.
Any help would be greatly appreciated;
Orange_Cyborg
Can you see what driver is loaded for the board when it is plugged in? Do you have drivers for it?
Thanks for the reply, the board is basically a modified Uno but I tried my actual Uno and it works fine, but this board brings up errors. This is the actual board: SparkFun RedBot Mainboard - ROB-12097 - SparkFun Electronics .
The guides for the RedBot all say you just plug it in and it works as an Uno, so I guess I have the drivers for it.
Hope this answers your questions
Orange_Cyborg
The Uno R3 uses a different USB to serial converter. You need the FTDI drivers for the USB to serial converter available from FTDI's website.
I updated the VCP driver for the FTDI chip on the board(FT232R) and this fixed my problem: FT232RQ (NRND) - FTDI
I had previously updated the D2XX but did't see the VCP, my error.
Thanks for the help!
No problem! Have a good time playing with your new board!
