Is analogRead() function supposed to work with Arduino Portenta yet? My attempts doing so have failed so far. I tried to use the basic arduino examples (analogRead() - Arduino Reference) but I am only able to get zeros to the serial.
-analog
-analog
I have been trying with an application to provide an analog output using the Portenta but have failed to get anything other than zero output (see DAC from Portenta H7 - Portenta H7 - Arduino Forum).
Having read this post, I have just tried to make an analogRead using the Portenta H7 using the code from the analogRead reference page.
I can't get anything other than zero input, so I'm observing the same problem that was reported here. I wonder if the ADC and DAC problems are related...
I seem to be going the same path as you did, as I'm currently trying to familiarize myself with stm32cube software...
Sorry for the inconvenience.
There was a mishap during the merge of mbed 6.0 and pins A0-A3 ended up being ignored during a call to analogRead().
You can read about it here, the core will be updated today
Enjoy
Thank you @ubidefeo!
It works flawlessly now
A follow up question:
Is external analog reference supported yet?
Can someone check what I am doing wrong. I have MBED board version 1.2.1, I am running this simple blink, analogRead, serial code
/* Blink, AnalogRead and Serial
* Arduino test program
* By Jeremy Ellis twitter @rocksetta
* Alternate connecting A0 to 3V3 and then to Ground
* Best to use a variable resistor the 3 wires to A0, GND, 3V3
void setup(){
pinMode(LED_BUILTIN, OUTPUT);
// while (!Serial); // Please don't do this it messes up beginners
int sensorValue = analogRead(A0);
Serial.print("A0 Analog Read max = 1023, Actual Value: ");
Serial.println(sensorValue);
// Flash LED 3 times
digitalWrite(LED_BUILTIN, LOW);
delay(100);
digitalWrite(LED_BUILTIN, HIGH);
delay(100);
delay(100);
delay(100);
delay(100);
delay(3000); // longer wait
When I run it on a Nano 33 IOT I get sensible results from 0 to 1023, but when I run it on the Portenta. First and most important A5 crashes the board to flashing red and disconnects the serial monitor.
Jer,
I made the same mistake using A5 and crashing my board. Can you describe how you have reset yours?
I have managed to make analogRead() to work but the moment I try and include analogWrite() on a pin, neither of them work.
joshgoldberg:
Jer,I made the same mistake using A5 and crashing my board. Can you describe how you have reset yours?
Josh, not sure if I did anymore than double push the reset button. I have crashed my Portenta so much. I am getting used to the double reset on first plugin and then it seems fairly good at finding the port after that.
P.S. mBed board manager version 1.2.2 fixes the A5 crash, now allows A0-A6 to analogRead, only with AREF connected to 3V3.
jerteach,
I confirmed A5 ok right now (1.2.2) as well:
Used this sketch - note - A5 is just floating (still have my H7 in a test harness...)
Analog input, analog output, serial output
Reads an analog input pin, maps the result to a range from 0 to 255 and uses
the result to set the pulse width modulation (PWM) of an output pin.
Also prints the results to the Serial Monitor.
The circuit:
created 29 Dec. 2008
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
// These constants won't change. They're used to give names to the pins used:
const int analogInPin = A5; // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
// initialize serial communications at 9600 bps:
// read the analog in value:
sensorValue = analogRead(analogInPin);
// map it to the range of the analog out:
// outputValue = map(sensorValue, 0, 1023, 0, 255);
// change the analog out value:
// analogWrite(analogOutPin, outputValue);
// print the results to the Serial Monitor:
Serial.print("sensor = ");
// Serial.print("\t output = ");
// Serial.println(outputValue);
// wait 2 milliseconds before the next loop for the analog-to-digital
// converter to settle after the last reading:
19:57:07.438 -> sensor = 233
19:57:08.413 -> sensor = 233
19:57:09.416 -> sensor = 227
19:57:10.437 -> sensor = 230
19:57:11.432 -> sensor = 225
19:57:12.402 -> sensor = 229
19:57:13.402 -> sensor = 233
19:57:14.403 -> sensor = 224
19:57:15.408 -> sensor = 229
19:57:16.413 -> sensor = 226
19:57:17.408 -> sensor = 232
19:57:18.396 -> sensor = 226
19:57:19.397 -> sensor = 225
19:57:20.396 -> sensor = 232
19:57:21.396 -> sensor = 235
19:57:22.413 -> sensor = 240
19:57:23.396 -> sensor = 241
19:57:24.393 -> sensor = 226
19:57:25.399 -> sensor = 237
19:57:26.405 -> sensor = 247
19:57:27.383 -> sensor = 239
19:57:28.380 -> sensor = 233
19:57:29.384 -> sensor = 222
19:57:30.388 -> sensor = 224
I'll try the rest.
Regards,
John W.
For reference:
Using this sketch:
The circuit:
- potentiometer connected to analog pin 0.
Center pin of the potentiometer goes to the analog pin.
side pins of the potentiometer go to +5V and ground
- LED connected from digital pin 9 to ground
modified 9 Apr 2012
by Tom Igoe
http://www.arduino.cc/en/Tutorial/AnalogInOutSerial
unsigned short counter = 0;
int analogInPin = A0; // Analog input pin that the potentiometer is attached to
switch ( counter++ )
case 0:
analogInPin = A0;
// counter++;
case 1:
analogInPin = A1;
case 2:
analogInPin = A2;
case 3:
analogInPin = A3;
case 4:
analogInPin = A4;
case 5:
analogInPin = A5;
case 6:
analogInPin = A6;
counter = 0;
default:
analogInPin = A0;
counter = 0;
Serial.print(counter);
Serial.print(" sensor = :");
I got this output:
20:20:44.694 -> 0 sensor = :490
20:20:45.713 -> 1 sensor = :21
20:20:46.693 -> 2 sensor = :11
20:20:47.697 -> 3 sensor = :18
20:20:48.703 -> 4 sensor = :14
20:20:49.672 -> 5 sensor = :230
20:20:50.664 -> 6 sensor = :235
20:20:51.672 -> 0 sensor = :560
20:20:52.683 -> 1 sensor = :18
20:20:53.681 -> 2 sensor = :16
20:20:54.683 -> 3 sensor = :13
20:20:55.693 -> 4 sensor = :14
20:20:56.663 -> 5 sensor = :238
20:20:57.682 -> 6 sensor = :229
20:20:58.671 -> 0 sensor = :565
20:20:59.676 -> 1 sensor = :17
20:21:00.681 -> 2 sensor = :19
20:21:01.656 -> 3 sensor = :16
20:21:02.679 -> 4 sensor = :16
20:21:03.649 -> 5 sensor = :240
20:21:04.651 -> 6 sensor = :232
20:21:05.655 -> 0 sensor = :561
20:21:06.657 -> 1 sensor = :14
20:21:07.646 -> 2 sensor = :19
20:21:08.665 -> 3 sensor = :15
20:21:09.673 -> 4 sensor = :16
20:21:10.662 -> 5 sensor = :236
20:21:11.632 -> 6 sensor = :249
HTH,
John W.
