Hi, I'm trying to use DHT22 with TTGO T-Call ESP32. But, its not working. It is continuously failing to receive data from the sensor. I have tried connecting the vcc of the sensor to the 3.3V, 5V and Vin pin of TTGO T-Call ESP32, but nothing works. On the other hand, it works fine with ESP32 Dev module. I'm unable to find out whats wrong here. While uploading code at TTGO T-Call ESP32, I choose the ESP32 Wrover module. There is no problem with uploading the data. I found this code on the internet. Please help me.
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
#include <Adafruit_Sensor.h>
#include <DHT.h>
// Replace with your network credentials
const char* ssid = "Tesla";
const char* password = "isc20177";
#define DHTPIN 27 // Digital pin connected to the DHT sensor
// Uncomment the type of sensor in use:
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String readDHTTemperature() {
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
//float t = dht.readTemperature(true);
// Check if any reads failed and exit early (to try again).
if (isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return "--";
else {
Serial.println(t);
return String(t);
String readDHTHumidity() {
float h = dht.readHumidity();
if (isnan(h)) {
return "--";
else {
Serial.println(h);
return String(h);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
<style>
html {
font-family: Arial;
display: inline-block;
margin: 0px auto;
text-align: center;
h2 { font-size: 3.0rem; }
p { font-size: 3.0rem; }
.units { font-size: 1.2rem; }
.dht-labels{
font-size: 1.5rem;
vertical-align:middle;
padding-bottom: 15px;
</style>
</head>
<body>
<h2>ESP32 DHT Server</h2>
<p>
<i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
<span class="dht-labels">Temperature</span>
<span id="temperature">%TEMPERATURE%</span>
<sup class="units">°C</sup>
</p>
<p>
<i class="fas fa-tint" style="color:#00add6;"></i>
<span class="dht-labels">Humidity</span>
<span id="humidity">%HUMIDITY%</span>
<sup class="units">%</sup>
</p>
</body>
<script>
setInterval(function ( ) {
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("temperature").innerHTML = this.responseText;
xhttp.open("GET", "/temperature", true);
xhttp.send();
}, 10000 ) ;
document.getElementById("humidity").innerHTML = this.responseText;
xhttp.open("GET", "/humidity", true);
xhttp.send();
}, 10000 ) ;
</script>
</html>)rawliteral";
// Replaces placeholder with DHT values
String processor(const String& var){
//Serial.println(var);
if(var == "TEMPERATURE"){
return readDHTTemperature();
else if(var == "HUMIDITY"){
return readDHTHumidity();
return String();
void setup(){
// Serial port for debugging purposes
dht.begin();
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
// Print ESP32 Local IP Address
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html, processor);
server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", readDHTTemperature().c_str());
server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", readDHTHumidity().c_str());
// Start server
server.begin();
void loop(){
Unfortunately you failed to provide links to the used hardware. If your TTGO board is the one from Lilygo you simply used a pin to connect the DHT which is already used by the onboard SIM800 module.
That probably means there's something wrong in the circuit or the code. Post a complete wiring diagram and the complete (adapted) code! Post links to all used hardware! Post links to the used libraries (there are at least 4 libraries out there called DHT.h)!
I have connected the Vcc of the DHT22 to the Vin of the TTgo board, Signal pin of the sensor board to the digital pin 27 of the ttgo board, also connected a 4.7k ohm resistor between the signal pin and the vcc line and connected the ground to the ground. And I'm using the DHT library which is available in the arduino IDE. Later, I tried connecting the signal pin to digital pin 26,15,2. But still there was no data. With the same code and same wiring(connecting signal pin of sensor to digital pin 2 of ttgo board) I was able to receive data from esp32 easily.
#include "WiFi.h"
#include <DHT.h>
if (isnan(t)) {
return "--";
else {
Serial.println(t);
return String(t);
if (isnan(h)) {
return "--";
else {
Serial.println(h);
return String(h);
<head>
<style>
html {
font-family: Arial;
margin: 0px auto;
text-align: center;
.dht-labels{
font-size: 1.5rem;
</style>
</head>
<body>
<p>
</p>
<p>
</p>
</body>
<script>
xhttp.send();
}, 10000 ) ;
xhttp.send();
}, 10000 ) ;
</script>
return String();
void setup(){
dht.begin();
// Connect to Wi-Fi
// Start server
server.begin();
void loop(){
}`Preformatted text`
