unable to use EEPROM functions of ATtiny13A
this is the code i uploaded to my ATtiny13A using my Arduino UNO as an ISP Programmer...
the program is like if i cut my IR sensor for 7 times .. then only my led switches on..
i want it in such a way that even if the power for the ic is cut off the ic should start from the point where it
stopped ...so i am storing the number of times i cut the sensor in EEPROM of the ic...
but the EEPROM part of the code is not working..
i need a bit of help here on how to write and read the EEPROM of ATtiny13A...??
please...
#include<EEPROM.h>
int ir=1;
int led=4;
int a=0;
boolean b=LOW;
pinMode(led,OUTPUT);
pinMode(button,INPUT);
a=EEPROM.read(0);
if(a==7)
a=0;
if(digitalRead(button)==HIGH&&b==LOW&&a<7)
a++;
EEPROM.write(0,a);
b=HIGH;
if(digitalRead(button)==LOW&&b==HIGH)
b=LOW;
if(a==7)
digitalWrite(led,HIGH);
If you are using smeezekitty's core you can take a look at this:
http://forum.arduino.cc/index.php?topic=89781.150
