Unable to use output to switch on relay
(deleted)
First measure up port 6 output voltage.
Arduino Yun 5v pin doesnt give me 5v, all the digital output will be suffer as well
http://forum.arduino.cc/index.php?topic=209836.msg1541065#msg1541065
The standard MOSFET and only turns on when Vgs=10V or higher.
For Arduino Yun, which only outputs 4.4V, you will need a logic-level MOSFET. For this type of MOSFET, Vgs=4.4V is enough to turn it on.
(deleted)
FQP27P06. 60V P-Channel MOSFET
RDS(on) Static Drain-Source
On-Resistance VGS = -10 V, ID = -13.5 A -- 0.055 0.07 ?
You need N-channel logic-level power MOSFET. 3.3 V type is fine but 5.0 v should be ok.
sonnyyu:
Why stop at 3.3 V, Vishay has a lot of them for even as low as 1.2 v.
Special applications
2.5 V rated on-resistance (255)
1.5 V rated on-resistance (52)
1.2 V rated on-resistance (19)
1.2 V rated on-resistance | MOSFETs | Vishay
1.5 V rated on-resistance | MOSFETs | Vishay
2.5 V rated on-resistance | MOSFETs | Vishay
(deleted)
Most of them are transistors but MOSFET, You might have better luck post same question at General Electronics Forum.
http://forum.arduino.cc/index.php?board=5.0
(deleted)
