Unable to use the "rawRecv" example from the Seeed Arduino IR library
Seeed Arduino IR - Arduino Reference
The board I am using is an Arduino Uno WiFi Rev. 2.
Here is the error message (in Arduino preferences, verbose output was enabled, and "Compiler warnings" was set to "All"):
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno WiFi Rev2, None (ATMEGA4809)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\tcdd\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\tcdd\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\tcdd\Documents\Arduino\libraries -fqbn=arduino:megaavr:uno2018:mode=off -vid-pid=03EB_2145 -ide-version=10819 -build-path C:\Users\tcdd\AppData\Local\Temp\arduino_build_506505 -warnings=all -build-cache C:\Users\tcdd\AppData\Local\Temp\arduino_cache_321469 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.arduinoOTA.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\examples\rawRecv\rawRecv.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\tcdd\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\tcdd\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\tcdd\Documents\Arduino\libraries -fqbn=arduino:megaavr:uno2018:mode=off -vid-pid=03EB_2145 -ide-version=10819 -build-path C:\Users\tcdd\AppData\Local\Temp\arduino_build_506505 -warnings=all -build-cache C:\Users\tcdd\AppData\Local\Temp\arduino_cache_321469 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.arduinoOTA.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\examples\rawRecv\rawRecv.ino
Using board 'uno2018' from platform in folder: C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7
Using core 'arduino' from platform in folder: C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7
Detecting libraries used...
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\sketch\\rawRecv.ino.cpp" -o nul
Alternatives for IRLibRecvPCI.h: [Seeed_Arduino_IR@1.0.2]
ResolveLibrary(IRLibRecvPCI.h)
  -> candidates: [Seeed_Arduino_IR@1.0.2]
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\sketch\\rawRecv.ino.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibDecodeBase.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibFreq.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibHardware.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibProtocols.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibRecv.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibRecvBase.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibRecvLoop.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibRecvPCI.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibSAMD21.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibSAMD51.cpp" -o nul
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibSendBase.cpp" -o nul
Generating function prototypes...
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\sketch\\rawRecv.ino.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\sketch\\rawRecv.ino.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\sketch\\rawRecv.ino.cpp.o"
Compiling libraries...
Compiling library "Seeed_Arduino_IR"
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibDecodeBase.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\libraries\\Seeed_Arduino_IR\\IRLibDecodeBase.cpp.o"
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibProtocols.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\libraries\\Seeed_Arduino_IR\\IRLibProtocols.cpp.o"
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibFreq.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\libraries\\Seeed_Arduino_IR\\IRLibFreq.cpp.o"
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibHardware.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\libraries\\Seeed_Arduino_IR\\IRLibHardware.cpp.o"
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibDecodeBase.cpp: In member function 'void IRdecodeBase::dumpResults(bool)':
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibDecodeBase.cpp:56:8: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
        if(interval>0)LowSpace=min(LowSpace, interval);  HiSpace=max (HiSpace, interval);
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibDecodeBase.cpp:56:57: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the 'if'
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibDecodeBase.cpp: In member function 'bool IRdecodeBase::MATCH(int16_t, int16_t)':
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibDecodeBase.cpp:130:15: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
   return (val >= (uint16_t)(expected*(1.0-PERCENT_TOLERANCE/100.0)))
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibDecodeBase.cpp:131:15: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       && (val <= (uint16_t)(expected*(1.0+PERCENT_TOLERANCE/100.0)));
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibRecv.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\libraries\\Seeed_Arduino_IR\\IRLibRecv.cpp.o"
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibRecvBase.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\libraries\\Seeed_Arduino_IR\\IRLibRecvBase.cpp.o"
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibRecvLoop.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\libraries\\Seeed_Arduino_IR\\IRLibRecvLoop.cpp.o"
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibRecvPCI.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\libraries\\Seeed_Arduino_IR\\IRLibRecvPCI.cpp.o"
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecvBase.cpp: In function 'void IRLib_IRrecvComplete(uint8_t)':
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecvBase.cpp:159:35: warning: unused parameter 'Reason' [-Wunused-parameter]
 void IRLib_IRrecvComplete(uint8_t Reason) {
In file included from C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecv.cpp:14:0:
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecv.cpp: In member function 'virtual void IRrecv::enableIRIn()':
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:301:4: error: 'TCCR2A' was not declared in this scope
    TCCR2A = _BV(WGM21);   TCCR2B = _BV(CS21); \
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecv.cpp:42:5: note: in expansion of macro 'IR_RECV_CONFIG_TICKS'
     IR_RECV_CONFIG_TICKS();
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:301:4: note: suggested alternative: 'TCB2'
In file included from c:\users\tcdd\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\io.h:99:0,
                 from c:\users\tcdd\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5\avr\include\avr\pgmspace.h:90,
                 from C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/String.h:31,
                 from C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/IPAddress.h:24,
                 from C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/api/ArduinoAPI.h:30,
                 from C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/Arduino.h:23,
                 from C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibGlobals.h:18,
                 from C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecvBase.h:20,
                 from C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecv.h:16,
                 from C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecv.cpp:13:
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:301:17: error: 'WGM21' was not declared in this scope
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:301:27: error: 'TCCR2B' was not declared in this scope
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:301:27: note: suggested alternative: 'TCB2'
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:301:40: error: 'CS21' was not declared in this scope
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:302:4: error: 'OCR2A' was not declared in this scope
    OCR2A = IR_RECV_COUNT_TOP / 8;   TCNT2 = 0; })
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:302:37: error: 'TCNT2' was not declared in this scope
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:302:37: note: suggested alternative: 'TCB2'
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:291:34: error: 'TIMSK2' was not declared in this scope
  #define IR_RECV_ENABLE_INTR    (TIMSK2 = _BV(OCIE2A))
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecv.cpp:43:5: note: in expansion of macro 'IR_RECV_ENABLE_INTR'
     IR_RECV_ENABLE_INTR;
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:291:34: note: suggested alternative: 'TIMERB2'
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:291:47: error: 'OCIE2A' was not declared in this scope
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecv.cpp: In member function 'virtual void IRrecv::disableIRIn()':
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:292:34: error: 'TIMSK2' was not declared in this scope
  #define IR_RECV_DISABLE_INTR   (TIMSK2 = 0)
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecv.cpp:53:3: note: in expansion of macro 'IR_RECV_DISABLE_INTR'
   IR_RECV_DISABLE_INTR; //Defined in IRLibTimer.h disables 50us timer interrupt
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:292:34: note: suggested alternative: 'TIMERB2'
In file included from C:\Users\tcdd\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\cores\arduino/Arduino.h:27:0,
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecv.cpp: In function 'void TIMER2_COMPA_vect()':
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibHardware.h:293:37: warning: 'TIMER2_COMPA_vect' appears to be a misspelled 'interrupt' handler, missing '__vector' prefix [-Wmisspelled-isr]
  #define IR_RECV_INTR_NAME      ISR(TIMER2_COMPA_vect,ISR_NOBLOCK)
C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR\src\IRLibRecv.cpp:86:1: note: in expansion of macro 'IR_RECV_INTR_NAME'
 IR_RECV_INTR_NAME {
"C:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\tcdd\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "-IC:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src" "C:\\Users\\tcdd\\Documents\\Arduino\\libraries\\Seeed_Arduino_IR\\src\\IRLibSAMD21.cpp" -o "C:\\Users\\tcdd\\AppData\\Local\\Temp\\arduino_build_506505\\libraries\\Seeed_Arduino_IR\\IRLibSAMD21.cpp.o"
Using library Seeed_Arduino_IR at version 1.0.2 in folder: C:\Users\tcdd\Documents\Arduino\libraries\Seeed_Arduino_IR
exit status 1
Error compiling for board Arduino Uno WiFi Rev2.
have you checked if the library is compatible with Arduino Uno WiFi Rev2?? (using Microchip ATmega4809 microcontroller)
from the doc:
Supported platforms include most 8-bit AVR Arduino boards such as Arduino Uno, Leonardo, and Mega 256. Also supports boards with SAMD 21 processor such as Arduino Zero, Arduino M0 Pro, Adafruit Feather M0, Adafruit Circuit Playground Express, Adafruit Trinket M0, Adafruit Gemma M0, and Arduino MKR 1000. Now supports SAMD51 boards such as Adafruit Feather M4, Adafruit Metro M4, and Adafruit Grand Central M4.
