I've attempted to verify the sketch example in the tutorial - https://docs.arduino.cc/tutorials/mkr-env-shield/mkr-env-shield-basic
I've just copied & pasted the sketch after connecting the MKR 1010 with MKR_ENV shield attached to Arduino.cc IOT Cloud which provided the "connect to IOT Cloud" part of the sketch - it shows up as a Device with a Thing ID
Hoping for assistance - thanks
I get this error on Line 53:
/usr/local/bin/arduino-cli compile --fqbn arduino:samd:mkrwifi1010 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/004756163/build --build-path /tmp/arduino-build-D4B1E6A391A5D6CEE48DCC184FD58E6D --library /home/builder/opt/libraries/arduino_mkrenv_1_2_1 --library /home/builder/opt/libraries/arduinocloudthing_1_7_3 /tmp/004756163/Untitled_jan21a
Using library adafruit_sleepydog_library_1_6_0 at version 1.6.0 in folder: /home/builder/opt/libraries/adafruit_sleepydog_library_1_6_0
Using library SPI at version 1.0 in folder: /home/builder/.arduino15/packages/arduino/hardware/samd/1.8.12/libraries/SPI
/tmp/004756163/Untitled_jan21a/Untitled_jan21a.ino: In function 'void loop()':
/tmp/004756163/Untitled_jan21a/Untitled_jan21a.ino:53:14: error: a function-definition is not allowed here before '{' token
/tmp/004756163/Untitled_jan21a/Untitled_jan21a.ino:64:13: error: a function-definition is not allowed here before '{' token
/tmp/004756163/Untitled_jan21a/Untitled_jan21a.ino:105:1: error: expected '}' at end of input
Error during build: exit status 1
This is the Sketch:
// Arduino_MKRENV - Version: 1.2.1
#include <Arduino_MKRENV.h>
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/46709497-1584-4135-aed3-e05951c26154
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
float humidity;
float illuminance;
float pressure;
float temperature;
float uVA;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
while (!Serial);
if (!ENV.begin()) {
Serial.println("Failed to initialize MKR ENV shield!");
while (1);
// read all the sensor values
float temperature = ENV.readTemperature();
float humidity = ENV.readHumidity();
float pressure = ENV.readPressure();
float illuminance = ENV.readIlluminance();
float uva = ENV.readUVA();
float uvb = ENV.readUVB();
float uvIndex = ENV.readUVIndex();
// print each of the sensor values
Serial.print("Temperature = ");
Serial.print(temperature);
Serial.println(" °C");
Serial.print("Humidity = ");
Serial.print(humidity);
Serial.println(" %");
Serial.print("Pressure = ");
Serial.print(pressure);
Serial.println(" kPa");
Serial.print("Illuminance = ");
Serial.print(illuminance);
Serial.println(" lx");
Serial.print("UVA = ");
Serial.println(uva);
Serial.print("UVB = ");
Serial.println(uvb);
Serial.print("UV Index = ");
Serial.println(uvIndex);
// print an empty line
// wait 1 second to print again
