Unable to verify or upload/exit status 1
I am using windows 10 with the current arduino IDE 1.8.2
Whenever I try to verify it comes up with the same error which in turn does not allow me to upload to the arduino itself.
I have tried running the IDE as an admin and have also checked many times to make sure that I have the correct board and port selected.
Using the given examples, it is still unable to verify. I have checked to see if the drivers needed updated but still nothing. bootloader is installed as the led on the board next to pin 13 is blinking
Below is what I was trying to verify as well as the the error message that it has been giving me.
Any and all help is very much appreciated.
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino model, check
the Technical Specs of your board at https://www.arduino.cc/en/Main/Products
This example code is in the public domain.
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
c:\program files (x86)\arduino\hardware\tools\avr\bin../lib/gcc/avr/4.9.2/../../../../avr/bin/ar.exe: unable to rename 'C:\Users\Spencer\AppData\Local\Temp\arduino_build_579579\core\core.a'; reason: Permission denied
exit status 1
Error compiling for board Arduino/Genuino Uno.
Usually that's caused by an overzealous antivirus program blocking the compiler from doing it's job.
OMG I love you. It worked. I cannot thank you enough. I can't believe that something so simple would be the problem. Now it's time for new headaches. Again, thank you so much.
