Unable to Visually return the Column Num
int ColumnPins = 4; //How many column pins
int RowPins = 5; //How many row pins
int Columns = {0, 1, 2, 3}; //Column pinNumbers
int Rows = {4, 6, 7, 8, 9}; //Row pinNumbers
pinMode(13, OUTPUT);
for (int counter = 0; counter < ColumnPins; counter++)
{ //set all the columns to output
pinMode(Columns[counter], OUTPUT);
for (int counter = 0; counter < RowPins; counter++)
{ //set all rows to input
pinMode(Rows[counter],INPUT_PULLDOWN);
for (int ColumnIndex = 0; ColumnIndex < ColumnPins; ColumnIndex++) //sets column pins to high 1 by 1
digitalWrite(Columns[ColumnIndex], HIGH);
RowScan(ColumnIndex); //calls function rowscan checks whether and row is HIGH
void RowScan(int ColumnIndex) //Scans each rowpin and checks whether any reads high
for (int RowIndex = 0; RowIndex < RowPins; RowIndex++)
if (digitalRead(Rows[RowIndex]) == HIGH) //if Rows at rowindex is high
for (int blinks = 0; blinks <= RowIndex; blinks++)
{ //Outputs # of blinks based on which row HIGH was read
// print index
digitalWrite(13, HIGH); //LEDPIN high
delay(250);
digitalWrite(13, LOW);
for (int blinks = 0; blinks <= ColumnIndex; blinks++)
// print index
delay(100);
delay(100);
else if (digitalRead(Rows[RowIndex]) == LOW) //Rows at index o is LOW
digitalWrite(13,LOW);
i believe the issue specifically lies within the for loop
Which one? The one in loop() or the one in RowScan()?
The RowScan() function has no idea which column is active, so you can't expect it to "visually output the column number", whatever that means.
You lied when you said that RowScan would return an int. Why?
RowScan SHOULD return an int - the row that is active, or -1 if none. Then, loop() would know what column and what row was selected.
Shouldn’t you set the pins to LOW, just in case?
Shouldn’t you set the column pin back to LOW before going on to the next column?
Yes ^ that may be an issue I overlooked will change tonight
