Sorry, code didn’t post.
//Libraries
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_INA260.h>
#include <SdFat.h>
#include <Adafruit_SPIFlash.h>
#include "ArduinoLowPower.h"
// On-board external flash (QSPI or SPI) macros should already
// defined in your board variant if supported
// - EXTERNAL_FLASH_USE_QSPI
// - EXTERNAL_FLASH_USE_CS/EXTERNAL_FLASH_USE_SPI
#if defined(EXTERNAL_FLASH_USE_QSPI)
Adafruit_FlashTransport_QSPI flashTransport;
#elif defined(EXTERNAL_FLASH_USE_SPI)
Adafruit_FlashTransport_SPI flashTransport(EXTERNAL_FLASH_USE_CS, EXTERNAL_FLASH_USE_SPI);
#else
#error No QSPI/SPI flash are defined on your board variant.h !
#endif
Adafruit_SPIFlash flash(&flashTransport);
// file system object from SdFat
FatFileSystem fatfs;
// Configuration for the datalogging file:
#define FILE_NAME "data.csv"
Adafruit_INA260 ina260 = Adafruit_INA260();
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET 7 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
//Pins definitions
#define enterPin 9
#define upPin 10
#define downPin 11
#define XtiltPin 2
#define YtiltPin 3
//Declare variables
uint8_t sequence = 0; //sequence of main program
float upVolt = 25.0; //up voltage limit
float loVolt = 10.0; //down voltage limit
float voltage; //measure voltage sensor
float current; //measure current sensor
volatile bool Xtilt; //measure x tilt sensor
volatile bool Ytilt; //measure y tilt sensor
bool up, down, enter; //measure the state of the buttons
uint16_t timer; //take the 100ms time
uint16_t timeTilt; //take the 5 minutes tilt time
uint16_t timeSave; //time when the voltage measure is out of range
//pins as input
pinMode(enterPin, INPUT_PULLUP);
pinMode(upPin, INPUT_PULLUP);
pinMode(downPin, INPUT_PULLUP);
pinMode(XtiltPin, INPUT_PULLUP);
pinMode(YtiltPin, INPUT_PULLUP);
Serial.begin(9600); //initialize the serial transmition at 9600 bauds
//=======Oled Initialize===================
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(WHITE); // Draw white text
display.clearDisplay();
//=====INA260 Initialize=====================
if (!ina260.begin()) {
Serial.println("Couldn't find INA260 chip");
// while (1);
//=====Initialize flash library=============
if (!flash.begin()) {
Serial.println("Error, failed to initialize flash chip!");
//while(1);
// First call begin to mount the filesystem. Check that it returns true
// to make sure the filesystem was mounted.
if (!fatfs.begin(&flash)) {
Serial.println("Error, failed to mount newly formatted filesystem!");
Serial.println("Was the flash chip formatted with the fatfs_format example?");
//while(1);
if (sequence == 0) { //configuring the Voltage upper limit
display.setCursor(5, 0);
display.print(F("Voltage upper limit"));
display.setCursor(45, 15);
display.print(upVolt);
display.print(F(" V"));
display.display();
readButtons();
if (up == LOW && upVolt < 33.0) {
display.fillRect(0, 0, 128, 32, BLACK);
upVolt += 0.01;
delay(200);
else if (down == LOW && upVolt > 0.0) {
upVolt -= 0.01;
delay(200);
else if (enter == LOW) {
display.display();
sequence = 1;
delay(200);
else if (sequence == 1) { //configuring the Voltage lower limit
display.print(F("Voltage lower limit"));
display.print(loVolt);
display.display();
readButtons();
if (up == LOW && loVolt < upVolt - 1.0) {
loVolt += 0.01;
delay(200);
else if (down == LOW && loVolt > 0.0) {
loVolt -= 0.01;
delay(200);
display.display();
sequence = 2;
delay(200);
timeTilt = millis();
else if (sequence == 2) { //reading the voltage sensor each 100ms
if (millis() - timer > 100) {
voltage = ina260.readBusVoltage() * 1000.0;
Serial.print("Voltage="); Serial.println(voltage);
if (voltage < loVolt || voltage > upVolt) { //if the measure voltage is out of range
current = ina260.readCurrent() * 1000.0; //reading the current
saveFlash();
timeSave += 100;
timer = millis();
readTilt();
void readButtons() {
enter = digitalRead(enterPin);
up = digitalRead(upPin);
down = digitalRead(downPin);
void readTilt() {
Xtilt = digitalRead(XtiltPin);
Ytilt = digitalRead(YtiltPin);
if (Xtilt == CHANGE || Ytilt == CHANGE) {
Serial.println("Tilt activated");
if (millis() - timeTilt > 300000 ) { //5min * 60 sec = 300 sec = 300000 ms --> go to sleep
Serial.println("Go to sleep...zzzz");
// Attach a wakeup interrupt on pin XtiltPin and YtiltPin, calling repetitionsIncrease when the device is woken up
LowPower.attachInterruptWakeup(XtiltPin, wakeUpBoard, CHANGE);
LowPower.attachInterruptWakeup(YtiltPin, wakeUpBoard, CHANGE);
// Triggers an infinite sleep (the device will be woken up only by the registered wakeup sources)
// The power consumption of the chip will drop consistently
LowPower.sleep();
void wakeUpBoard() {
Serial.println("Wake up!");
sequence = 2;
detachInterrupt(XtiltPin);
detachInterrupt(YtiltPin);
void saveFlash() {
// Open the datalogging file for writing. The FILE_WRITE mode will open
// the file for appending, i.e. it will add new data to the end of the file.
File dataFile = fatfs.open(FILE_NAME, FILE_WRITE);
// Check that the file opened successfully and write a line to it.
if (dataFile) {
// Write a line to the file. You can use all the same print functions
// as if you're writing to the serial monitor. For example to write
// two CSV (commas separated) values:
dataFile.print("Voltage=");
dataFile.print(",");
dataFile.print(voltage, DEC);
dataFile.print("V");
dataFile.print("Current=");
dataFile.print(current, DEC);
dataFile.print("A");
dataFile.print("Time=");
dataFile.print(timeSave, DEC);
dataFile.print("ms");
dataFile.println();
// Finally close the file when done writing. This is smart to do to make
// sure all the data is written to the file.
dataFile.close();
Serial.println("Wrote new measurement to data file!");
else {
Serial.println("Failed to open data file for writing!");
