method 1:
#ifndef GPSport_h
#define GPSport_h
// Copyright (C) 2014-2017, SlashDevin
// This file is part of NeoGPS
// NeoGPS is free software: you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation, either version 3 of the License, or
// (at your option) any later version.
// NeoGPS is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with NeoGPS. If not, see <http://www.gnu.org/licenses/>.
// There are 2 ways this file can be used:
// I. AS IS, which tries to *guess* which port a beginner should use.
// If you include <SoftwareSerial.h>, <NeoSWSerial.h>, <AltSoftSerial.h>,
// <NeoICSerial.h> *OR* <NeoHWSerial.h> before this file (in the INO)
// or on line 152 below, one of those ports will be used for the GPS.
// This file cannot always guess what you want, so you may need to use it
// in the 2nd way...
// II. *REPLACE EVERYTHING* in this file to *specify* which port and
// which library you want to use for that port. Just declare the
// port here. You must declare three things:
// 1) the "gpsPort" variable (used by all example programs),
// 2) the string for the GPS_PORT_NAME (displayed by all example programs), and
// 3) the DEBUG_PORT to use for Serial Monitor print messages (usually Serial).
// The examples will display the device you have selected during setup():
// DEBUG_PORT.println( F("Looking for GPS device on " GPS_PORT_NAME) );
// Choosing the serial port connection for your GPS device is probably
// the most important design decision, because it has a tremendous impact
// on the processor load. Here are the possible configurations,
// from BEST to WORST:
// --- The BEST choice is to use a HardwareSerial port. You could use Serial
// on any board, but you will have to disconnect the Arduino RX pin 0
// from the GPS TX pin to upload a new sketch over USB. This is a very
// reliable connection:
// #define gpsPort Serial
// #define GPS_PORT_NAME "Serial"
// #define DEBUG_PORT Serial
// If you have a Mega, Leo or Due board, you could use Serial1,
// Serial2 or Serial3:
// #define gpsPort Serial1
// #define GPS_PORT_NAME "Serial1"
// These extra ports do not have to be disconnected to upload new
// sketches over USB.
// Use NeoHWSerial if you want to handle GPS characters
// in an Interrupt Service Routine (see NMEA_isr.INO).
// Also uncomment NMEAGPS_INTERRUPT_PROCESSING in NMEAGPS_cfg.h.
// #include <NeoHWSerial.h>
// #define gpsPort NeoSerial
// #define GPS_PORT_NAME "NeoSerial"
// #define DEBUG_PORT NeoSerial
// Note that the DEBUG_PORT must be NeoSerial, not Serial
// (see NeoHWSerial documentation for additional requirements).
// --- The SECOND BEST choice is AltSoftSerial. It uses 10x to 500x
// more processor time than a HardwareSerial port, but it is the BEST
// *software* serial port library. It only works on two specific pins
// (see the AltSoftSerial documentation).
// #include <AltSoftSerial.h>
// AltSoftSerial gpsPort; // 8 & 9 for an UNO
// #define GPS_PORT_NAME "AltSoftSerial"
// Use NeoICSerial if you want to handle GPS characters
// #include <NeoICSerial.h>
// NeoICSerial gpsPort; // 8 & 9 for an UNO
// #define GPS_PORT_NAME "NeoICSerial"
// --- The THIRD BEST choice is NeoSWSerial. It is almost as efficient as
// AltSoftSerial, but it only supports baud rates 9600, 19200 or 38400.
// #include <NeoSWSerial.h>
// NeoSWSerial gpsPort(3, 2);
// #define GPS_PORT_NAME "NeoSWSerial(3,2)"
// NeoSWSerial supports handling GPS characters in an Interrupt Service
// Routine (see NMEA_isr.INO). If you want to do that, also uncomment
// NMEAGPS_INTERRUPT_PROCESSING in NMEAGPS_cfg.h.
// --- The WORST choice is SoftwareSerial. IT IS NOT RECOMMENDED because
// it disables interrupts for the entire time a character is sent OR
// received. This interferes with other parts of your sketch or with
// other libraries. It prevents receiving or sending data on any other
// port. It cannot transmit and receive at the same time. 95% of the
// CPU time will be spent twiddling its thumbs. It may support 57600,
// but 115200 is rarely reliable.
// #include <SoftwareSerial.h>
// SoftwareSerial gpsPort(2,3);
// #define GPS_PORT_NAME "SoftwareSerial(8,9)"
// You should *seriously* consider using other pins or lower baud rates,
// so that you could use one of the other recommended ports.
// DEFAULT file contents:
// *GUESS* which port should be used. If you know what port you want to use,
// *DELETE* the rest of this file and declare your own GPS port variable,
// GPS port name string, and debug print port variable (see above).
#if defined(SERIAL_PORT_HARDWARE_OPEN)
#if SERIAL_PORT_HARDWARE_OPEN == Serial1
// This Arduino has more than one hardware serial port,
// use Serial1 (or NeoSerial1).
#define NEOGPS_USE_SERIAL1
#endif
#endif
#ifdef NEOGPS_USE_SERIAL1
#if defined( NMEAGPS_INTERRUPT_PROCESSING )
#define gpsPort NeoSerial1
#define GPS_PORT_NAME "NeoSerial1"
#else
#endif
#else
// Uncomment *zero* or *one* of the serial port library includes.
// If none of these includes are uncommented, Serial will be used.
//#include <NeoHWSerial.h> // NeoSerial or NeoSerial1 Interrupt-style processing
//#include <AltSoftSerial.h> // <-- DEFAULT. Two specific pins required
//#include <NeoICSerial.h> // AltSoftSerial with Interrupt-style processing (see docs)
//#include <NeoSWSerial.h> // Any pins, only @ 9600, 19200 or 38400 baud
//#include <SoftwareSerial.h> // NOT RECOMMENDED!
#if defined( SoftwareSerial_h )
#define SS_TYPE SoftwareSerial
#warning SoftwareSerial is NOT RECOMMENDED. Use AltSoftSerial or NeoSWSerial instead.
#error You cannot use SoftwareSerial with INTERRUPT_PROCESSING. Use NeoSWSerial or NeoICSerial instead.
#endif
#elif defined( NeoSWSerial_h )
#define SS_TYPE NeoSWSerial
#elif defined( AltSoftSerial_h )
#define SS_TYPE AltSoftSerial
#define RX_PIN -1 // doesn't matter because it only works...
#define TX_PIN -1 // ...on two specific pins
#error You cannot use AltSoftSerial with INTERRUPT_PROCESSING. Use NeoICSerial instead.
#endif
#elif defined( NeoICSerial_h )
#define SS_TYPE NeoICSerial
#elif defined( NeoHWSerial_h )
#warning Using Serial (actually NeoSerial) for GPS connection.
#else
// No serial library files were included before this file, just use Serial.
#warning Using Serial for GPS connection.
// You will see this warning if you want to use Serial for the GPS, because no
// software serial port libraries were included. That is a good choice.
// To use a different serial port for GPS device, you must include a serial header
// before "#include GPSport.h" in the INO. It may be simpler to replace the
// entire contents of this file with your own declarations. Follow the
// instructions above for declaring your own "gpsPort" variable. Everything else
// in this file should be deleted. See Installation instructions for more
// information.
#endif
#endif
#ifdef SS_TYPE
// The current Board (an Uno?) does not have an extra serial port.
// Use a software serial library to listen to the GPS device.
// You should expect to get some RX errors, which may
// prevent getting fix data every second. YMMV.
// Default Arduino RX pin number that is connected to the GPS TX pin
#ifndef RX_PIN
#define RX_PIN 4
#endif
// Default Arduino TX pin number that is connected to the GPS RX pin
#ifndef TX_PIN
#define TX_PIN 3
#endif
SS_TYPE gpsPort( RX_PIN, TX_PIN );
// A little preprocessor magic to get a nice string
#define xstr(x) str(x)
#define str(x) #x
#define GPS_PORT_NAME \
xstr(SS_TYPE) "( RX pin " xstr(RX_PIN) \
", TX pin " xstr(TX_PIN) " )"
// If you *really* want to do this, or you just happened to include
// a software serial library header for something else, you're
// better off *not* including this file. Just declare
// your own gpsPort in your INO file.
#error You should be using Serial1 for the GPS device. \
Software serial libraries are very inefficient and unreliable when \
used for GPS communications!
#endif
#endif
// When NeoHWSerial is used, none of the built-in HardwareSerial
// variables can be used: Serial, Serial1, Serial2 and Serial3
// *cannot* be used. Instead, you must use the corresponding
// NeoSerial, NeoSerial1, NeoSerial2 or NeoSerial3. This define
// is used to substitute the appropriate Serial variable in
// all debug prints.
#ifdef NeoHWSerial_h
#else
#define DEBUG_PORT Serial // default for most sketches
#endif
// End of guessing game.
#endif
method 2:
#ifndef GPSport_h
#define GPSport_h
#endif
