First post here, so hi to everyone
I recently started to play with Arduino for two main reasons: learn/refresh electronics skills and to learn C. In the last years I've been mostly coding in Python so I think it's better if I push myself into a completely new field where I can't have the temptation to go back to a language I already know.
My first project is a circuit that "accumulates" button presses and then sends key presses at certain fixed rate. The button will trigger a LED blink. Easy, but I'm trying to do it with a bit of object oriented programming that I can use in other projects.
I created one class for the LEDs that I can initialize with the pin number and a blink delay so I can control their brightness (I quickly discovered that if you simply switch on-off the LEDs the amount of light perceived by the eyes is too low. So, the way to periodically call that blinking led could something as simple as:
#include "ledslib.h"
// Variables initialization
Led o_led(8, 30); // Led connected to pin 8 that will blink for 30 ms
// Setup code
o_led.init();
// Main loop
o_led.blink();
// Update of all the "automatic" objects in the program
o_led.update();
Now comes the tricky part... I want to create a Button class in a similar manner. It should be able to store:
- a Led instance (so I can link the button to a blinking LED).
- a function (so I can trigger any function I want when I press the button).
So far, my non-working Button class looks like:
class Button {
unsigned long i_start = 0; // Time when the button was pressed the last time
int i_delay = 100; // Minimum time between two consecutive presses
int i_pin = 0; // Pin associated to the button
bool b_on = false; // The internal state of the button
int *i_func; // The function that will be executed by the button
int *i_led; // Led pointer that will blink when the button is pressed
public:
Button(int pi_pin, int pi_delay, int pi_led) {
i_pin = pi_pin;
i_delay = pi_delay;
i_led = pi_led;
void init() {
pinMode(i_pin, INPUT);
void press() {
if (!b_on) {
b_on = true;
i_start = millis();
if (i_led != 0) {
*i_led.blink();
The problem is I don't know how to properly do both things. I've been reading about how to store pointers/references to other class instances or functions but I'm really confused and not making any progress. Examples of the things I've trying are:
class Button {
int i_func = 0; // The function that will be executed by the button
Led *o_led; // Led pointer that will blink when the button is pressed
public:
Button(int pi_pin, int pi_delay, int *po_led) {
o_led = po_led;
void press() {
if (!b_on) {
b_on = true;
if (o_led != NULL) {
o_led.blink();
Any help or guidance will be more than welcome. Please remember I have a background in Python so basic stuff like getting/storing/using pointers/references from classes/instances/functions is quite overwhelming at the moment.
Regards
