@pert
Like others before me in this topic I have a Nano 33 IOT that is not recognised when connected using USB and will not go into bootloader mode with a double tap on the reset button
I have Uno, classic Nano, ESP32 and ESP8266 boards but I am unclear whether any of these can be used to burn the bootloader to the Nano IOT
Way back in post #2 you said
but the example Adafruit DAP library > flash_from_SD does not appear in the file list when Uno or Nano is selected as the board
The file does exist but copying it into the IDE and compiling for a Uno does not work because there is not enough memory
I get the same result. It might be that some of the recent development on the library (seems to be very active) has increased the memory usage, or maybe I only compiled it for Mega (My go-to AVR board for quick tests). You could try rolling back through versions of the library to see if one will compile.
I see they recently added support to the library for using ESP8266 and ESP32 as programmers, so you might give those a try.
Great work! Even though it wasn't a fun experience for me to break my board, in the end I was glad that it gave me the motivation to learn about recovering the SAMD boards. I now feel much more free to experiment with those boards without fear of making an expensive mistake, even to the point of intentionally bricking boards so I can reproduce the conditions of the person I'm trying to help.
The mistake reported here of having the Nano 33 BLE board selected when uploading to a SAMD board is the most common.
The first time I bricked a SAMD board, it was when I ran a random bossac command from a forum user directly from the command line. I don't remember the exact details of what it was now. I'm more accustomed to the AVR Boards where there is pretty much nothing you can do via a serial upload that will require a programmer to fix.
I am sure that I didn't have the Nano 33 BLE board selected as I don't have it installed. It is more likely that I had an AVR board selected or just possibly an ESP32
However, now that I can recover the board, albeit with some inconvenience, it does not really matter but I might try to reproduce the problem
I just bricked it again. I am still not sure of the exact sequence of events but I was doing much the same as I was the last time it happened trying to read serial data from a GPS
I have a GPS module powered from 3V3 and GND on the Nano. It works at 3V3, tested with an ESP32
Tx from the GPS is connected to Nano RX0.
Rx from the GPS is connected to TX1 on the Nano
Sketch as follows
while (!Serial);
Serial2.begin(115200); //GPS set up using u-centre
if (Serial2.available())
Serial.write(Serial2.read());
As far as I remember the sequence was :
With the serial connections not in place I can upload the sketch to the Nano but with them connected I get a Windows "last device not recognised" error. Double clicking the Nano reset button reconnects the Nano to the PC and it goes into bootloader mode (pulsing LED) as usual
However, having double clicked a couple of times there is no Windows connection sound, the pulsing LED is permanently off and no COM port is allocated and it remains the same with nothing connected
Once I have unbricked the Nano I will try it again but I will leave the DAP connections soldered in place this time
Bootloader reloaded in record time (I am getting good at it)
into bootloader mode again
Blink sketch uploads and works
did this several times with the GPS unpowered but with the Serial2 connections in place
connected GPS 3V3 and GND to Nano
uploaded Blink sketch - device not recognised
double click into bootloader mode
uploaded Blink sketch several times - all OK
deliberately selected the wrong port in IDE
changed back to Nano port - device not recognised
bricked again
Conclusions - I cannot make the problem occur consistently but it seems to have something to do with changing COM ports and/or by trying to use the wrong port then changing back to teh correct one
I am off to reload the bootloader again which is no problem now that I have soldered pins to the DAP pads
