Unclear how to fix error:
Hi everyone!
I’m in a programming class and we have just started using arduino. I’m supposed to write a program that will play a melody when my board is hooked up to a speaker. I typed out all of my code and cannot seem to get it to compile. The error message :Arduino-3.ino:47: error: expected unqualified-id before ‘{’ token" pops up, and I have triple checked all of my { and } to make sure they have matches. Any ideas on what is wrong?
My code is attached, and I will also copy and paste it. Thanks!
int c = 3830; //261 Hz
int d = 3400; //294 Hz
int e = 3038; //329 Hz
int f = 2864; //349 Hz
int g = 2550; //329 Hz
int a = 2272; //440 Hz
int b = 2028; //493 Hz
int C = 1912; //523 Hz
int R = 0;
////Function Definition ///////
void playTone(const int tone_, const long beat, const long tempo, const int speakerPin)
long duration = beat*tempo;
const int rest_count = 100;
long elapsed_time = 0;
if (tone_ > 0)
while (elapsed_time < duration)
digitalWrite(speakerPin,HIGH);
delayMicroseconds(tone_ / 2);
digitalWrite(speakerPin, LOW);
elapsed_time += (tone_);
for (int j = 0; j < rest_count; j++)
delayMicroseconds(duration);
//////End of Function Definition /////////
int speakerOutPin = 13;
pinMode(speakerOutPin, OUTPUT);
void loop();
long tempo= 10000: //Set overall tempo
playTone(C,16,tempo,speakerOutPin);
playTone(b,16,tempo,speakerOutPin);
playTone(g,16,tempo,speakerOutPin);
playTone(C,8 ,tempo,speakerOutPin);
playTone(b,8 ,tempo,speakerOutPin);
playTone(e,16,tempo,speakerOutPin);
playTone(R,32,tempo,speakerOutPin);
playTone(c,16,tempo,speakerOutPin);
playTone(a,8 ,tempo,speakerOutPin);
delayMicroseconds(2000000);
Arduino-3.ino (1.42 KB)
You have a semicolon here that should not be there:
void loop();
You have a spurious ; after void loop()
You have a ";" after the void loop ()
It should not be there because it is a function not a command
Without looking at your code, I'd guess you have an excess semi colon after your void loop declaration. I really don't know where I get this idea from, it just came to me like a psychic vision.
