Undead 78l05
I have a NTC-based temperature module which I connected in reverse causing its death. I thought that what was death was its 78l05 voltage regulator so I connected it again, correct polarity this time, and measured the voltage at the 78l05 output pin, nothing as expected.
Before replacing it I decided to inject 5v directly to that pin, without disconnecting the 12v, to check that the rest of the circuit still worked. It still worked but to my surprise it continued working after disconnecting the 5v supply.
Now it works normally and my question is: What caused this behavior?
That is strange... Sometimes electrolytic capacitors can be "rejuvenated" by a couple techniques, but I wouldn't have expected the reverse voltage to get through the regulator to the capacitor to damage it in the 1st place.
You mean 78L05?
I wish I had a dollar for every time I thought I blew something up and it turned out to be something simple....(OH NO !!!, and then YES !!)
I have previously described here a situation where I have a pack of really funny dodgy white LEDs, a number of which do not light on the LED tester but if I then give them a "burn" at 20 or 50 mA, they start working properly on the lower currents and appear to have cleared some sort of internal shunt resistance.
A 7805 will get spit sizzle hot and start to smell if connected incorrectly to a strong power supply. But after I blistered my finger and connected the 7805 correctly, it still worked.
Paul__B:
I wonder if this is a "whiskers" issue. A real problem with led free production.
Here is a PDF link to a NASA document.
MeSat:
Was that a Freudian Slip of sorts?
Sounds like overcurrent or overtemperature shutdown. The regulator will recover from
either usually.
zoomkat:
zoomkat:
Thermal protection worked then! :slight_smile:
