#undef isn't explicitly documented
I wonder why a standard C term #undef isn't explicitly documented comparing to #define which is explained:
Is it unsupported or what else? By mistake?
Because the docs are an overview of things that an inexperienced programmer might want to know. They do not cover all the intricacies of C/C++.
shkaff:
#define - Arduino Reference
See Index of Directives (The C Preprocessor) and the parent pages.
What am I missing here? To my mind this is a simple software question about #undef . No change to the Arduino project has been proposed and none is required. #undef is a command within the C pre-processor (cpp) which has been in cpp for as long as I can remember and I have been using cpp for 30 odd years.
This should be moved back to to where it belongs - the "Programming Questions" forum.
I don't see it as a programming question. It is asking why documentation of #undef does not exist on the reference pages whereas #define does.
Pete
In which case it needs to be raised as an Arduino documentation bug and not just left to fester here.
I have just tried the #undef because I have a need to use a variation of the servo library for a single servo but require an interrupt driven timer for a model clock. So though simple: undefined _useTimer5, which will then allow me to define my own ISR for timer5.
Good idea while it lasted! It doesn't work so appears not to be supported.
Works for me.
