Undefined Index error when posting to mySQL
im attempting to post data to a mySQL database using an ESP8266 shield and XAMPP, when trying to post a variable to the database, i am getting an error that reads and an output of 0 in all the columns of the SQL table.
+IPD,0,345:
<b>Notice</b>:  Undefined index: lic_no in <b>C:\xampp\htdocs\test.php</b> on ieb1/>b/
r/<>oc<> Ueidid:se nbCxmpto\e.h<>oln >2b<r>< ><Ntc/> nfn ne oao  bCxm\to\e.h<>oln<>2b< >Eeedt cefly,LE
is this a problem with the syntax in my attached PHP file?
test.txt (612 Bytes)
That error message is telling you that the variable 'lic_no' was not found in the query string- perhaps you have a spelling error in your code somewhere?
Have you looked in the web-server log on the php side? That should give you a clue about what is sent from the ESP8266.
So im getting a null Value on the SQL database, not the value that im sending. From forums that I've read, i dont think i have initialised the variable properly but after following many instructions, i am still getting exactly the same result
amg982:
The code on the Arduino (or pretender) is?
The PHP script is?
The log file contains?
With just some frustrated hand waving, you don't really expect help, do you?
