undefined reference to `Adafruit_PWMServoDriver::Adafruit_PWMServoDriver(unsigne
Hello, how do i solve this error now that i'm testing my library.
I followed the discussion here SOLVED: Problem compiling code error: "undefined Reference to 'Timer1'" - Programming Questions - Arduino Forum but it didn't go away.
Here is my code.
#ifndef _Car_h
#define _Car_h
#if ARDUINO >= 100
 #include "Arduino.h"
#else
 #include "WProgram.h"
#endif
#include <../Adafruit_PWMServoDriver/Adafruit_PWMServoDriver.h>
class Car{
  public:
    Car();
    void turnLeft();
    Adafruit_PWMServoDriver pwm  = Adafruit_PWMServoDriver();
#endif
Car.cpp
#include "Car.h"
Car::Car(){
  setLargestCornerAngle(17);
void Car::turnLeft(){
      int pulselength = map(90-17, 0, 180, SERVOMIN, SERVOMAX);
      pwm.setPWM(servonum, 0, pulselength);
Using the car object
#include <Car.h>
Car car;
Check the library directory
Should be
#include <Adafruit_PWMServoDriver.h>
And Adafruit_PWMServoDriver.h should be in a folder in Documents/Arduino/libraries.
I didn't test that but I would check this entry first, because the error you get usually means "I can't find this library".
You can NOT hide the fact that Car.h uses Adafruit_PWMServoDriver.h from the sketch. Trying to do so results in the EXACT error messages you are seeing.
