When I compile my main code, it gives me an error and I read up about it but couldn't find anything.
* The Effect abstract class for the GauntletII project.
#ifndef Effect_h
#define Effect_h
#import <FastLED.h>
class Effect {
protected:
CRGB *leds;
int width, height;
struct CRGB& pixel(int x, int y);
bool inXRange(int x);
bool inYRange(int y);
void clearLeds();
public:
Effect(CRGB *leds, int width, int height);
virtual void start() {};
#endif
Arduino: 1.8.8 (Mac OS X), Board: "Arduino/Genuino Uno"
In file included from sketch/Effect.h:8:0,
from sketch/twinkle.cpp:5:
/Users/jonathanfelix/Documents/Arduino/libraries/FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.002.000
# pragma message "FastLED version 3.002.000"
from sketch/twinkle.cpp:5,
from /Users/jonathanfelix/Documents/Arduino/sd_card_lights/sd_card_lights.ino:4:
/var/folders/sn/s5gtxzh907q8mmf73yr8fjs40000gn/T//ccEmA6Db.ltrans1.ltrans.o: In function `Twinkle::Twinkle(CRGB*, int, int, bool, bool)':
sketch/twinkle.cpp:27: undefined reference to `Effect::Effect(CRGB*, int, int)'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
You posted incomplete code. Please supply enough so that we can reproduce the same compiler error.
the rest is really messy I need to organize it and get rid of some variables I'm not using.
#include "twinkle.cpp"
int crn = 1;
#define HEIGHT 14
#define WIDTH 14
#include <FastLED.h>
#define NUM_LEDS WIDTH * HEIGHT
#include <SPI.h>
#include <SD.h>
#define DATA_PIN 3 // your data arduino pin
#define CHIPSET WS2812B // your LED chip type
#define CMD_NEW_DATA 1
//#define BAUD_RATE 500000 //if using Glediator via serial
const byte interruptPin = 2;
unsigned char x = 14; // matrix x size
unsigned char y = 14; // matrix y size
volatile int buttoncount = 0;
static unsigned long last_interrupt_time = 0;
#define MAX_TWINKS 25
#define OFFSET 0xB000
File fxdata;
CRGB leds[NUM_LEDS];
void irpt(){
unsigned long interrupt_time = millis();
// debounce
if ((interrupt_time - last_interrupt_time) > 100)
if(buttoncount==8){
buttoncount=0;
buttoncount++;}
Serial.println(buttoncount);
last_interrupt_time = interrupt_time;
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), irpt, LOW);
FastLED.addLeds<CHIPSET, DATA_PIN, GRB>(leds, NUM_LEDS); //see doc for different LED strips
// Serial.begin(BAUD_RATE); // when using Glediator via usb
for(int y = 0 ; y < NUM_LEDS ; y++)
leds[y] = CRGB::Black; // set all leds to black during setup
FastLED.show();
pinMode(10, OUTPUT); // CS/SS pin as output for SD library to work.
if (!SD.begin(4))
Serial.println("sdcard initialization failed!");
return;
Serial.println("sdcard initialization done.");
int serialGlediator ()
{while (!Serial.available()) {}
return Serial.read(); }
void loop(){
//first
while(buttoncount==0){
if (buttoncount!=0){fxdata.close(); break;}
fxdata = SD.open("pl.dat");
Serial.println("Good");
fxdata.close();
if (fxdata){
fxdata.close();
while (fxdata.available()){
fxdata.close();
fxdata.readBytes((char*)leds, NUM_LEDS*3);
fxdata.close();
ledSort(crn);
fxdata.close();
}//1-4 possible, set your first LED's position. Change the number: 1=TL(top left),2=TR(top right),3=BL(bottom left),4=BR(bottom right)
FastLED.show();
fxdata.close();
delay(10);
fxdata.close();
}// set the speed of the animation. 20 is appx ~ 500k bauds
fxdata.close();
fxdata.close();
//second
while(buttoncount==1){
if (buttoncount!=1){
fxdata.close();
break;}
fxdata = SD.open("slow.dat");
fxdata.close();
if (fxdata){
fxdata.close();
fxdata.close();
fxdata.close();
ledSort(crn);
fxdata.close();
FastLED.show();
fxdata.close();
delay(10);
fxdata.close();
fxdata.close();
fxdata.close();
//third
while(buttoncount==2){
if (buttoncount!=2){
fxdata.close();
break;}
fxdata = SD.open("cplasma.dat");
fxdata.close();
if (fxdata){
fxdata.close();
fxdata.close();
fxdata.close();
ledSort(crn);
fxdata.close();
FastLED.show();
fxdata.close();
delay(10);
fxdata.close();
fxdata.close();
fxdata.close();
//fourth
while(buttoncount==3){
if (buttoncount!=3){
fxdata.close();
break;}
fxdata = SD.open("fire.dat");
fxdata.close();
if (fxdata){
fxdata.close();
fxdata.close();
fxdata.close();
ledSort(crn);
fxdata.close();
FastLED.show();
fxdata.close();
delay(20);
fxdata.close();
fxdata.close();
fxdata.close();
Heres the first part its too big to post at one time
The Effect.cpp file is not being included in your build (or it doesn't define the object constructor).
That, in itself is an unusual thing to do.
Bugflip:
Agreed. Better to post an MCVE
and heres the second part
//fifth
while(buttoncount==4){
if (buttoncount!=4){
fxdata.close();
break;}
fxdata = SD.open("frac.dat");
fxdata.close();
if (fxdata){
fxdata.close();
fxdata.close();
fxdata.close();
ledSort(crn);
fxdata.close();
FastLED.show();
fxdata.close();
delay(20);
fxdata.close();
fxdata.close();
fxdata.close();
//sixth
while(buttoncount==5){
if (buttoncount!=5){fxdata.close();break;}
if (buttoncount!=5){fxdata.close();break;}if (fxdata){
if (buttoncount!=5){fxdata.close();break;}}
fxdata.close();
fxdata.close();
ledSort(4);
fxdata.close();
FastLED.show();
fxdata.close();
delay(10);
fxdata.close();
fxdata.close();
fxdata.close();
//seventh
while(buttoncount==6){
if (buttoncount!=6){fxdata.close();break;}
fxdata = SD.open("sd.dat");
if (buttoncount!=6){fxdata.close();break;}if (fxdata){
if (buttoncount!=6){fxdata.close();break;}}
fxdata.close();
fxdata.close();
ledSort(4);
fxdata.close();
FastLED.show();
fxdata.close();
delay(10);
fxdata.close();
fxdata.close();
fxdata.close();
//eight
while(buttoncount==7){
if (buttoncount!=7){fxdata.close();break;}
fxdata = SD.open("lines.dat");
if (buttoncount!=7){fxdata.close();break;}if (fxdata){
if (buttoncount!=7){fxdata.close();break;}}
fxdata.close();
fxdata.close();
ledSort(4);
fxdata.close();
FastLED.show();
fxdata.close();
delay(10);
fxdata.close();
fxdata.close();
fxdata.close();
while(buttoncount==8){
doTwinkle();
void doTwinkle() {
Twinkle twinkle(leds, WIDTH, HEIGHT, true, true);
twinkle.start();
int ledSort (int modus) { //1=TL,2=TR,3=BL,4=BR, this function will rearrange the led array ;-)
CRGB tmp[x];
if(modus == 3 || modus == 4) {
for(int i = 0; i < (y / 2);i++) {
for(int j = 0; j < x;j++) {
tmp[j] = leds[i * x + j];
leds[i * x] = leds[(y - i - 1) * x];
leds[(y - i - 1) * x] = tmp[j];
if(modus == 1 || modus == 3) {
for(int i = 1; i < y; i = i + 2) {
for(int j = x; j > 0;j--) {
tmp[(x - j)] = leds[i * x + j - 1];
leds[i * x + j] = tmp[j];
if(modus == 2 | modus == 4) {
for(int i = 0; i < y; i = i + 2) {
return 1;
#import <FastLED.h>
We don't '#import' in C++.
