Undefined Reference to function error
Hey guys i have a problem again ... :confused:
Arduino: 1.6.5 (Windows 8.1), Platine: "Arduino/Genuino Uno"
C:\Users\Paul\AppData\Local\Temp\build3280561619484866464.tmp\flyController.cpp.o: In function Gyro::Gyro()': C:\Users\Paul\AppData\Local\Temp\build3280561619484866464.tmp/Gyro.h:14: undefined reference to MPU6050me::MPU6050me()'
C:\Users\Paul\AppData\Local\Temp\build3280561619484866464.tmp\Gyro.cpp.o: In function Gyro::GetVals()': C:\Users\Paul\AppData\Local\Temp\build3280561619484866464.tmp/Gyro.cpp:85: undefined reference to MPU6050me::getIntStatus()'
C:\Users\Paul\AppData\Local\Temp\build3280561619484866464.tmp/Gyro.cpp:87: undefined reference to MPU6050me::getFIFOCount()' C:\Users\Paul\AppData\Local\Temp\build3280561619484866464.tmp/Gyro.cpp:90: undefined reference to MPU6050me::resetFIFO()'
C:\Users\Paul\AppData\Local\Temp\build3280561619484866464.tmp/Gyro.cpp:96: undefined reference to MPU6050me::getFIFOBytes(unsigned char*, unsigned char)' C:\Users\Paul\AppData\Local\Temp\build3280561619484866464.tmp/Gyro.cpp:95: undefined reference to MPU6050me::getFIFOCount()'
collect2.exe: error: ld returned 1 exit status
Fehler beim Kompilieren.
I cant find my fault and when i'm googleing i just find that someone missed the class:: in front of the function or that they compiled in command with g++ and had written the wrong command...:confused:
Mpu5060me.h MPU5060me.h - Pastebin.com
Mpu5060me.cpp MPU5060cppcpp - Pastebin.com
Gyro.cpp Gyro.cpp - Pastebin.com
btw its not my code i just tried to modify it that it works for me/ fitted my needs...
MFG paul
I do not bother to load all that scattered pastebin stuff.
Maybe this can give you some hints:
We cannot give you any solutions if we do not have your sketch t look for the problems.
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom.... :slight_smile:
Hey Guys,
sure :slight_smile: i just couldn't post the other source in code format because it's too long :confused:
 Created:	03.10.2015 16:36:45
 Author:	Paul
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#endif
#include "ypr.h"
#include "Servo.h"
#include "Motor.h"
#include "Gyro.h"
#include "Wire.h"
#include "I2Cdev.h"
#include "helper_3dmath.h"
#include "MPU6050me.h"
#include "flyController.h"
#include "QuadCop.h"
QuadCop quad;
	quad = *new QuadCop(0,1,2,3);
	quad.setYPR(0, 0, 0);
// the loop function runs over and over again until power down or reset
	quad.Stableize();
Quadcop.h
// QuadCop.h
#ifndef _QUADCOP_h
#define _QUADCOP_h
	#include "arduino.h"
	#include "ypr.h"
#else
	#include "WProgram.h"
#endif
class QuadCop{
private:
	FlyController flyCon;
public:
	QuadCop(int motorPin1, int motorPin2, int motorPin3, int motorPin4);
	QuadCop();
	void setYPR(float Yaw,float Pitch, float Roll);
	void setYPR(YPR ypr);
	void Stableize();
#endif
QuadCop.cpp
QuadCop::QuadCop(int motorPin1, int motorPin2, int motorPin3,int motorPin4){
	flyCon = *new FlyController(motorPin1, motorPin2, motorPin3, motorPin4);
void QuadCop::setYPR(float Yaw, float Pitch, float Roll)
	flyCon.setWantedYPR(*new YPR(Yaw, Pitch, Roll));
void QuadCop::setYPR(YPR ypr)
	flyCon.setWantedYPR(ypr);
QuadCop::QuadCop(){
void QuadCop::Stableize(){
	flyCon.Refresh();
// Gyro.h
#ifndef _GYRO_h
#define _GYRO_h
#include "Wire.h"
#include "I2Cdev.h"
#include "ypr.h"
#endif
class Gyro{
private:
	MPU6050me mpu;
#define LED_PIN 13 // (Arduino is 13, Teensy is 11, Teensy++ is 6)
	bool blinkState;
	// MPU control/status vars
	bool dmpReady = false;  // set true if DMP init was successful
	uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
	uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
	uint16_t fifoCount;     // count of all bytes currently in FIFO
	uint8_t fifoBuffer[64]; // FIFO storage buffer
	uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
	// orientation/motion vars
	Quaternion q;           // [w, x, y, z]         quaternion container
	VectorInt16 aa;         // [x, y, z]            accel sensor measurements
	VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
	VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
	VectorFloat gravity;    // [x, y, z]            gravity vector
	float euler[3];         // [psi, theta, phi]    Euler angle container
	float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
	// packet structure for InvenSense teapot demo
	uint8_t teapotPacket[14] = { '
Gyro.cpp
#include "Gyro.h"
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
//#include"Wire.h"
#endif
volatile bool Gyro::mpuInterrupt = false;
YPR lastRedYPR;
void dmpDataReady() {
	Gyro::setMpuIntStatus(true);
static void setMpuIntStatus(volatile bool status)
	Gyro::mpuInterrupt = status;
void Gyro::init() {
	mpu = *new MPU6050me();
	lastRedYPR = *new YPR();
	// join I2C bus (I2Cdev library doesn't do this automatically)
	Wire.begin();
	TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
	Fastwire::setup(400, true);
#endif
	while (!Serial); // wait for Leonardo enumeration, others continue immediately
	Serial.println(F("Initializing I2C devices..."));
	mpu.initialize();
	// verify connection
	Serial.println(F("Testing device connections..."));
	Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
	// wait for ready
	Serial.println(F("\nSend any character to begin DMP programming and demo: "));
	while (Serial.available() && Serial.read());
	while (!Serial.available());
	// load and configure the DMP
	Serial.println(F("Initializing DMP..."));
	devStatus = mpu.dmpInitialize();
	mpu.setXGyroOffset(220);
	mpu.setYGyroOffset(76);
	mpu.setZGyroOffset(-85);
	mpu.setZAccelOffset(1788);
	if (devStatus == 0) {
		// turn on the DMP, now that it's ready
		Serial.println(F("Enabling DMP..."));
		mpu.setDMPEnabled(true);
		// enable Arduino interrupt detection
		Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
		attachInterrupt(0, dmpDataReady, RISING);
		mpuIntStatus = mpu.getIntStatus();
		// set our DMP Ready flag so the main loop() function knows it's okay to use it
		Serial.println(F("DMP ready! Waiting for first interrupt..."));
		dmpReady = true;
		packetSize = mpu.dmpGetFIFOPacketSize();
	else {
		Serial.print(F("DMP Initialization failed (code "));
		Serial.print(devStatus);
		Serial.println(F(")"));
	pinMode(LED_PIN, OUTPUT);
YPR Gyro::GetVals() {
	if (!dmpReady) return *new YPR(-1, -1, -1);
	while (!mpuInterrupt && fifoCount < packetSize) {
	fifoCount = mpu.getFIFOCount();
	if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
		mpu.resetFIFO();
		Serial.println(F("FIFO overflow!"));
		return *new YPR(-1,-1,-1);
	else if (mpuIntStatus & 0x02) {
		while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
		mpu.getFIFOBytes(fifoBuffer, packetSize);
		fifoCount -= packetSize;
		lastRedYPR.setNewVals(ypr[0] * 180 / M_PI, ypr[1] * 180 / M_PI, ypr[2] * 180 / M_PI);
		return lastRedYPR;
I posted a few code pieces more that you can understand the problem...
Thanks alot for help :slight_smile:
, 0x02, 0, 0, 0, 0, 0, 0, 0, 0, 0x00, 0x00, '\r', '\n' };
public:
volatile static bool mpuInterrupt; // indicates whether MPU interrupt pin has gone high
void static setMpuIntStatus(uint8_t status);
void init();
YPR GetVals();
#endif
Gyro.cpp
§DISCOURSE_HOISTED_CODE_4§
Thanks alot for help :)
Whandall:
Classes within Classes - Initialiser Lists
Thanks but i think it's not targeting my Problem...
I tried to regenerate your error here, but due to missing librarys gave up after some rounds of installing.
Your object contains subobjects, the linker complains about a nonexistent constructor,
so I still believe that the provided link is very much targeting your problem.
Your methode for object initialization seems very uncommon (at least to me)
QuadCop quad;
compared to a 'standard'
QuadCop *quad;
	quad = new QuadCop(0,1,2,3);
the latter not needing a copy operation.
Whandall:
QuadCop quad;
QuadCop *quad;
Hey there ....
Sry it seems that I'm in idiot... I Red the Post now the 6th time and if i understood it right i just have to copy in this into GYro.cpp dont i ? :confused:
Gyro::Gyro() : mpu()
if so it doesn't work ....
Okay thanks i changed my *new stuff :slight_smile:
Doesn't anyone know a solution ? :frowning:
