hello I am making a robotic arm but i cannot upload because i am getting this exact message:
/tmp/ccaEYa0P.ltrans0.ltrans.o: In function `main':
/home/admin/builder/opt/cores/arduino/avr/cores/arduino/main.cpp:43: undefined reference to `setup'
/home/admin/builder/opt/cores/arduino/avr/cores/arduino/main.cpp:46: undefined reference to `loop'
collect2: error: ld returned 1 exit status
exit status 1
here is my code:
#include <Servo.h>
const int servo1 = 3; // first servo
const int servo2 = 10; // second servo
const int joyH = 3; // L/R Parallax Thumbstick
const int joyV = 4; // U/D Parallax Thumbstick
const int servo1button = 6;
int servoVal; // variable to read the value from the analog pin
int switchPin = 7;
int counter = 0;
Servo myservo1; // create servo object to control a servo
Servo myservo2; // create servo object to control a servo
Servo myservo1button // create servo object to control a servo
// declare the switch pin as an input signal
pinMode (switchPin, INPUT);
servo1button.write(80);
// Servo
myservo1.attach(servo1); // attaches the servo
myservo2.attach(servo2); // attaches the servo
// Inizialize Serial
void loop(){
// Display Joystick values using the serial monitor
outputJoystick();
// Read the horizontal joystick value (value between 0 and 1023)
//servoVal = analogRead(joyH);
//servoVal = map(servoVal, 0, 1023, 0, 180); // scale it to use it with the servo (result between 0 and 180)
myservo2.write(servoVal); // sets the servo position according to the scaled value
servoVal = analogRead(joyV);
servoVal = map(servoVal, 0, 1023, 70, 180); // scale it to use it with the servo (result between 70 and 180)
myservo1.write(servoVal); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
Serial.println(buttonState);
if (buttonState == 0){
if (counter != 90){
//servo1.write (counter);
counter++;
//servo1.write (0);
counter = 0;
delay(10);
void outputJoystick(){
Serial.print(analogRead(joyH));
Serial.print("---");
Serial.print(analogRead(joyV));
Serial.println("----------------");
thank you very much
