Hello,
I'm trying to compile and upload the following sketch to an arduino Nano from Raspberry Pi. When I try it with the IDE it works fine, but when I try to compile and upload from Terminal it crashes.
This is the sketch:
#include <Wire.h>
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
#include "libraries/Grove_LCD_RGB_Backlight-master/rgb_lcd.h"
rgb_lcd lcd;
int index=1;
char msg[][15] = {
"Set Board Id ",
"Sensor tunning",
"Target Press. "
char msg[][16] = {
"Set Board Id ",
"Sensor tunning ",
"Target Pressure"
uint8_t empty[8] = {0x1F,0x11,0x11,0x11,0x11,0x11,0x11,0x1F};
//uint8_t selected[8] = {0x1F,0x0E,0x15,0x1B,0x1B,0x15,0x0E,0x1F};
byte selected[8] = {
0b11111,
0b11111,
0b11011,
0b10101,
0b10101,
0b11011,
0b11111,
0b11111
int count = 1;
int msgIdx = 0;
pinMode(4, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(6, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
pinMode(A0, INPUT_PULLUP);
delay(200);
// initialize the LCD
//lcd.begin();
lcd.begin(16,2);
delay(200);
lcd.clear();
lcd.createChar(1,empty);
lcd.createChar(2,selected);
// Turn on the blacklight and print a message.
//lcd.backlight();
if(digitalRead(6) == LOW){
msgIdx = (msgIdx + 1)%3;
if(digitalRead(7) == LOW){
msgIdx = (msgIdx + 2)%3;
Serial.print("Idx = ");
Serial.println(msgIdx);
if(index==1){
lcd.setCursor(0, 0);
lcd.print(msgIdx+1);
lcd.setCursor(1, 0);
lcd.print("-");
lcd.setCursor(2, 0);
}else{
lcd.print(msg[msgIdx]);
for(int i =0; i <3;i++){
lcd.setCursor(i+6, 1);
lcd.write(1);
lcd.setCursor(msgIdx+6, 1);
lcd.write(2);
//lcd.setCursor(2, 1);
//lcd.print(msg[(msgIdx+1)%3]);
if(digitalRead(A0)==false){
lcd.clear();
lcd.setCursor(0,0);
lcd.write("PROGRAMMING ...");
delay(200);
As I said, it works fine with the IDE. But when I compile it and upload from the Terminal I get the error.
The only code difference to make it work on the IDE is the #include statement.
Working on the IDE it is:
#include "rgb_lcd.h"
And to run on the Terminal and avoid complains of not finding the library, the include has to be:
The error/output I get in the Terminal is as follows:
pi@RPi-3:~/testMenu $ make upload clean
Arduino.mk Configuration:
- [AUTODETECTED] CURRENT_OS = LINUX
- [USER] ARDUINO_DIR = /usr/share/arduino
- [COMPUTED] ARDMK_DIR = /usr/share/arduino (relative to Common.mk)
- [AUTODETECTED] ARDUINO_VERSION = 105
- [DEFAULT] ARCHITECTURE =
- [DEFAULT] ARDMK_VENDOR = arduino
- [DEFAULT] ARDUINO_SKETCHBOOK =
- [BUNDLED] AVR_TOOLS_DIR = /usr/share/arduino/hardware/tools/avr (in Arduino distribution)
- [COMPUTED] ARDUINO_LIB_PATH = /usr/share/arduino/libraries (from ARDUINO_DIR)
- [COMPUTED] ARDUINO_VAR_PATH = /usr/share/arduino/hardware/arduino//variants (from ARDUINO_DIR)
- [COMPUTED] BOARDS_TXT = /usr/share/arduino/hardware/arduino//boards.txt (from ARDUINO_DIR)
- [DEFAULT] USER_LIB_PATH = /libraries (in user sketchbook)
- [DEFAULT] PRE_BUILD_HOOK = pre-build-hook.sh
- [USER] BOARD_SUB = atmega328
- [USER] BOARD_TAG = nano328
- [COMPUTED] CORE = arduino (from build.core)
- [COMPUTED] VARIANT = eightanaloginputs (from build.variant)
- [COMPUTED] OBJDIR = build-nano328-atmega328 (from BOARD_TAG)
- [COMPUTED] ARDUINO_CORE_PATH = /usr/share/arduino/hardware/arduino//cores/arduino (from ARDUINO_DIR, BOARD_TAG and boards.txt)
- [DETECTED] MONITOR_BAUDRATE = 9600 (in sketch)
- [DEFAULT] OPTIMIZATION_LEVEL = s
- [DEFAULT] MCU_FLAG_NAME = mmcu
- [DEFAULT] CFLAGS_STD = -std=gnu11 -flto -fno-fat-lto-objects
- [DEFAULT] CXXFLAGS_STD = -std=gnu++11 -fno-threadsafe-statics -flto
- [COMPUTED] DEVICE_PATH = /dev/ttyUSB* (from MONITOR_PORT)
- [DEFAULT] FORCE_MONITOR_PORT =
- [AUTODETECTED] Size utility: AVR-aware for enhanced output
- ARDUINO_LIBS =
- [SYSTEM] Wire
- [COMPUTED] BOOTLOADER_PARENT = /usr/share/arduino/hardware/arduino//bootloaders (from ARDUINO_DIR)
- [COMPUTED] ARDMK_VERSION = 1.5
- [COMPUTED] CC_VERSION = 5.4.0 (avr-gcc)
mkdir -p build-nano328-atmega328
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -x c++ -include Arduino.h -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto testMenu.ino -o build-nano328-atmega328/testMenu.ino.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -std=gnu11 -flto -fno-fat-lto-objects /usr/share/arduino/hardware/arduino//cores/arduino/wiring.c -o build-nano328-atmega328/core/wiring.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -std=gnu11 -flto -fno-fat-lto-objects /usr/share/arduino/hardware/arduino//cores/arduino/WInterrupts.c -o build-nano328-atmega328/core/WInterrupts.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -std=gnu11 -flto -fno-fat-lto-objects /usr/share/arduino/hardware/arduino//cores/arduino/wiring_digital.c -o build-nano328-atmega328/core/wiring_digital.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -std=gnu11 -flto -fno-fat-lto-objects /usr/share/arduino/hardware/arduino//cores/arduino/wiring_pulse.c -o build-nano328-atmega328/core/wiring_pulse.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -std=gnu11 -flto -fno-fat-lto-objects /usr/share/arduino/hardware/arduino//cores/arduino/wiring_analog.c -o build-nano328-atmega328/core/wiring_analog.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -std=gnu11 -flto -fno-fat-lto-objects /usr/share/arduino/hardware/arduino//cores/arduino/wiring_shift.c -o build-nano328-atmega328/core/wiring_shift.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -std=gnu11 -flto -fno-fat-lto-objects /usr/share/arduino/hardware/arduino//cores/arduino/avr-libc/realloc.c -o build-nano328-atmega328/core/avr-libc/realloc.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -std=gnu11 -flto -fno-fat-lto-objects /usr/share/arduino/hardware/arduino//cores/arduino/avr-libc/malloc.c -o build-nano328-atmega328/core/avr-libc/malloc.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/IPAddress.cpp -o build-nano328-atmega328/core/IPAddress.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/new.cpp -o build-nano328-atmega328/core/new.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/WString.cpp -o build-nano328-atmega328/core/WString.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/Tone.cpp -o build-nano328-atmega328/core/Tone.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/Print.cpp -o build-nano328-atmega328/core/Print.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/HID.cpp -o build-nano328-atmega328/core/HID.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/Stream.cpp -o build-nano328-atmega328/core/Stream.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/USBCore.cpp -o build-nano328-atmega328/core/USBCore.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/WMath.cpp -o build-nano328-atmega328/core/WMath.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/main.cpp -o build-nano328-atmega328/core/main.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/HardwareSerial.cpp -o build-nano328-atmega328/core/HardwareSerial.cpp.o
/usr/share/arduino/hardware/arduino//cores/arduino/HardwareSerial.cpp: In function ‘void store_char(unsigned char, ring_buffer*)’:
/usr/share/arduino/hardware/arduino//cores/arduino/HardwareSerial.cpp:100:9: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (i != buffer->tail) {
/usr/share/arduino/hardware/arduino//cores/arduino/HardwareSerial.cpp: In function ‘void __vector_18()’:
/usr/share/arduino/hardware/arduino//cores/arduino/HardwareSerial.cpp:129:21: warning: unused variable ‘c’ [-Wunused-variable]
unsigned char c = UDR0;
/usr/share/arduino/hardware/arduino//cores/arduino/HardwareSerial.cpp: In member function ‘void HardwareSerial::begin(long unsigned int, byte)’:
/usr/share/arduino/hardware/arduino//cores/arduino/HardwareSerial.cpp:370:11: warning: unused variable ‘current_config’ [-Wunused-variable]
uint8_t current_config;
/usr/share/arduino/hardware/arduino//cores/arduino/HardwareSerial.cpp: In member function ‘virtual size_t HardwareSerial::write(uint8_t)’:
/usr/share/arduino/hardware/arduino//cores/arduino/HardwareSerial.cpp:469:12: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
while (i == _tx_buffer->tail)
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/hardware/arduino//cores/arduino/CDC.cpp -o build-nano328-atmega328/core/CDC.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -std=gnu11 -flto -fno-fat-lto-objects /usr/share/arduino/libraries/Wire/utility/twi.c -o build-nano328-atmega328/libs/Wire/utility/twi.c.o
/usr/share/arduino/hardware/tools/avr/bin/avr-g++ -MMD -c -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=105 -D__PROG_TYPES_COMPAT__ -I/usr/share/arduino/hardware/arduino//cores/arduino -I/usr/share/arduino/hardware/arduino//variants/eightanaloginputs -I/usr/share/arduino/libraries/Wire -I/usr/share/arduino/libraries/Wire/utility -Wall -ffunction-sections -fdata-sections -Os -fpermissive -fno-exceptions -std=gnu++11 -fno-threadsafe-statics -flto /usr/share/arduino/libraries/Wire/Wire.cpp -o build-nano328-atmega328/libs/Wire/Wire.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc-ar rcs build-nano328-atmega328/libcore.a build-nano328-atmega328/core/wiring.c.o build-nano328-atmega328/core/WInterrupts.c.o build-nano328-atmega328/core/wiring_digital.c.o build-nano328-atmega328/core/wiring_pulse.c.o build-nano328-atmega328/core/wiring_analog.c.o build-nano328-atmega328/core/wiring_shift.c.o build-nano328-atmega328/core/avr-libc/realloc.c.o build-nano328-atmega328/core/avr-libc/malloc.c.o build-nano328-atmega328/core/IPAddress.cpp.o build-nano328-atmega328/core/new.cpp.o build-nano328-atmega328/core/WString.cpp.o build-nano328-atmega328/core/Tone.cpp.o build-nano328-atmega328/core/Print.cpp.o build-nano328-atmega328/core/HID.cpp.o build-nano328-atmega328/core/Stream.cpp.o build-nano328-atmega328/core/USBCore.cpp.o build-nano328-atmega328/core/WMath.cpp.o build-nano328-atmega328/core/main.cpp.o build-nano328-atmega328/core/HardwareSerial.cpp.o build-nano328-atmega328/core/CDC.cpp.o build-nano328-atmega328/libs/Wire/utility/twi.c.o build-nano328-atmega328/libs/Wire/Wire.cpp.o
/usr/share/arduino/hardware/tools/avr/bin/avr-gcc -mmcu=atmega328p -Wl,--gc-sections -Os -flto -fuse-linker-plugin -o build-nano328-atmega328/testMenu.elf build-nano328-atmega328/testMenu.ino.o build-nano328-atmega328/libcore.a -lc -lm
/tmp/ccHFXlaR.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_testMenu.ino.o.2056':
<artificial>:(.text.startup+0x90): undefined reference to `rgb_lcd::rgb_lcd()'
/tmp/ccHFXlaR.ltrans0.ltrans.o: In function `main':
<artificial>:(.text.startup+0x1fa): undefined reference to `rgb_lcd::begin(unsigned char, unsigned char, unsigned char, TwoWire&)'
<artificial>:(.text.startup+0x206): undefined reference to `rgb_lcd::clear()'
<artificial>:(.text.startup+0x214): undefined reference to `rgb_lcd::createChar(unsigned char, unsigned char*)'
<artificial>:(.text.startup+0x222): undefined reference to `rgb_lcd::createChar(unsigned char, unsigned char*)'
<artificial>:(.text.startup+0x2c0): undefined reference to `rgb_lcd::setCursor(unsigned char, unsigned char)'
<artificial>:(.text.startup+0x2f8): undefined reference to `rgb_lcd::setCursor(unsigned char, unsigned char)'
<artificial>:(.text.startup+0x310): undefined reference to `rgb_lcd::setCursor(unsigned char, unsigned char)'
<artificial>:(.text.startup+0x33c): undefined reference to `rgb_lcd::setCursor(unsigned char, unsigned char)'
<artificial>:(.text.startup+0x346): undefined reference to `rgb_lcd::write(unsigned char)'
<artificial>:(.text.startup+0x35c): undefined reference to `rgb_lcd::setCursor(unsigned char, unsigned char)'
<artificial>:(.text.startup+0x366): undefined reference to `rgb_lcd::write(unsigned char)'
<artificial>:(.text.startup+0x378): undefined reference to `rgb_lcd::clear()'
<artificial>:(.text.startup+0x384): undefined reference to `rgb_lcd::setCursor(unsigned char, unsigned char)'
collect2: error: ld returned 1 exit status
make: *** [/usr/share/arduino/Arduino.mk:1442: build-nano328-atmega328/testMenu.elf] Error 1
I've tried to look for the string "begin(unsigned char" in /usr/share/arduino/ but I can't find anywhere it is declared or used.
So I have no idea who is trying to use it.
The folder tree of the sketch is as follows:
sketchFolder
|-- Makefile
|-- testMenu.ino
|-- libraries/
|-- Grove_LCD_RGB_Backlight-master/
|-- examples/
|-- rgb_lcd.cpp
|-- rgb_lcd.h
So the questions are:
- What are the differences when compiling and uploading with the IDE and Terminal ?
- How can I solve this issue and who is trying to use this weird function call.
Thanks you in advance.
