undefined reference to `SerialCommand::SerialCommand()'
Macintosh 10.7.5
Arduion IDE 1.0.5
I am very new to programming, I have some experience with linux and Perl and ksh and bash. I am very new to .cpp
Here is the code ( I added void setup() and void loop() because they were not in the code. I have no idea if they are in the correct place. This is not my code, it was written for another IDE and I am trying to translate it to use in the Arduino IDE:
#include "CommandProcessing.h"
#include "PasswordManager.h"
#include "SerialCommand.h"
// ------------------ Serial command handler object.
SerialCommand CommandDispatcher;
// ------------------ Command handler prototypes
void InitializePasswordStore();
void ListPasswords();
void SetPassword();
void ClearPassword();
// ------------------ Command processing.
void InitializeCommandProcessing()
  CommandDispatcher.addCommand("init-pwd", InitializePasswordStore);
  CommandDispatcher.addCommand("list-pwd", ListPasswords);
  CommandDispatcher.addCommand("set-pwd", SetPassword);
void ProcessSerialInput()
  CommandDispatcher.readSerial();
// ------------------ Command handlers
  PasswordManager.InitializePasswordStore();
  PasswordManager.ListPasswords();
void SetPassword()
  char *pchSlot, *pchPassword;
  int nPassword;
  pchSlot = CommandDispatcher.next();
  pchPassword = CommandDispatcher.next();
  if (pchSlot == NULL || pchPassword == NULL)
    Serial.println(F("Error, format is: set-pwd n new-password\\r"));
    return;
  nPassword = atoi(pchSlot);
  PasswordManager.SetPassword(nPassword, pchPassword);
  char *pchSlot;
  int nPassword;
  if (pchSlot == NULL)
    Serial.println(F("Error, format is: clear-pwd n\\r"));
    return;
  PasswordManager.ClearPassword(nPassword);
This is the error. I have searched this site for the reasons, no luck:
CommandProcessing.cpp.o: In function `__static_initialization_and_destruction_0':
CommandProcessing.cpp:9: undefined reference to `SerialCommand::SerialCommand()'
CommandProcessing.h
1 /* ************************************************************************************************
  2 ** Serial command processing.
  3 ** ************************************************************************************************ */
  4
  5 #pragma once
  6 #include <Arduino.h>
  7
  8 void InitializeCommandProcessing();
  9 void ProcessSerialInput();
#include "/Volumes/optical/Users/michaelroberts/Documents/Arduino/libraries/CommandProcessing.h"
#include "/Volumes/optical/Users/michaelroberts/Documents/Arduino/libraries/PasswordManager.h"
#include "/Volumes/optical/Users/michaelroberts/Documents/Arduino/libraries/SerialCommand/SerialCommand.h"
This tells me that you haven't a clue about where libraries go, or how they are used on the Arduino.
This is the error
Which points to CommandProcessing.cpp, so you posted SerialCommand.h. Why, I can't even begin to imagine.
