undefined reference to Servo
Ok so this has probably been asked loads before, but I am new to arduino development and have googled but cant find the answer via google
so I have my own custom library called ARM
Arm.h
#ifndef Arm_h
#define Arm_h
#include "WProgram.h"
#include "../Servo/Servo.h"
class Arm {
  public:
    Arm(int servoPin, int motorPin);
    int getPosition();
    void setPosition(int pos);
    int getMotorSpeed();
    void setMotorSpeed(int mSpeed);
#endif
and
Arm.cpp
#include <Arm.h>
#include <../Servo/Servo.h>
int motorSpeed;
int servoPos;
Servo positionServo;
Arm::Arm(int servoPin, int motorPin) {
      positionServo.attach(servoPin);
void Arm::setPosition(int pos) {
  servoPos = pos;
void Arm::setMotorSpeed(int mSpeed) {
  motorSpeed = mSpeed;
int Arm::getPosition() {
  return servoPos;
int Arm::getMotorSpeed() {
  return motorSpeed;
then i have a basic sketch that I am trying to play with to see if i can get things working
#include <Arm.h>
// the arms
Arm tester(1, 2);
which gives the following error(s)
Arm\Arm.cpp.o: In function `__static_initialization_and_destruction_0':
C:\Program Files\arduino\libraries\Arm/Arm.cpp:9: undefined reference to `Servo::Servo()'
Arm\Arm.cpp.o: In function `Arm':
C:\Program Files\arduino\libraries\Arm/Arm.cpp:12: undefined reference to `Servo::attach(int)'
my questions are
why is this?
how do i fix it?
and from previous development experience hard coding the location of Servo.h can't be good surely? if not how do I get around this issue?
my class can be imported via the arduino IDE and works fine if i omit the servo stuff, but the thing I want to make requires a few servos and motorcontrollers (trying to get servos working forst though)
Thanks
Drogo
It's been asked many times. The answer is always the same. Include Servo.h in your sketch, too.
ah ha! thank you!
now about the path that ive had to hard code?
is this ok? when i push it onto my board (which is at home) will it still know where to look for it? is the structure similar enough for everything to work ok?
The compiler creates .o files from your source code, and libraries that you reference, in a temporary directory.
The linker links those .o files together to create a .hex file, in that same directory.
The uploader copies the .hex file onto the Arduino.
The Arduino then knows nothing about where the files on your computer are.
