Undefined Reference
I a trying to create a set of wrapper libraries around existing libraries with some common code that I use across projects. The tried to build a library on the OneWire library to see if the idea is feasible. The first problem with OneWire is it didn’t have a zero argument constructor, so I built one of those and a begin method to do the work that was done in the constructor.
Once I got it allmost compiled, I guess the last step of the compiler gives me the following errors.
Thermo\Thermo.cpp.o: In function Thermo::display()': C:\Arduino\arduino-1.0\libraries\Thermo/Thermo.cpp:38: undefined reference to OneWire::crc8(unsigned char*, unsigned char)’
Thermo\Thermo.cpp.o: In function Thermo::begin()': C:\Arduino\arduino-1.0\libraries\Thermo/Thermo.cpp:19: undefined reference to OneWire::begin(unsigned char)’
Thermo\Thermo.cpp.o: In function Thermo': C:\Arduino\arduino-1.0\libraries\Thermo/Thermo.cpp:11: undefined reference to OneWire::OneWire()’
Where these are the only references to the OneWire Instance variable
My Header looks like
#ifndef Thermo_h
#define Thermo_h
#include <Arduino.h>
#include "../OneWire/OneWire.h"
class Thermo
  public:
    Thermo(uint8_t pin, int count);
    void begin();
    void addThermo(byte *thermo);
    void display();
  private:
    uint8_t _pin;
    int _count; // the number allocated
    int _index; // the actual number added
    byte **_thermo;
    OneWire _ow;
#endif
and the implementation is
#include "Thermo.h"
#define thermoSize 8
Thermo::Thermo(uint8_t pin, int count) {
    pinMode(pin, OUTPUT);
    _pin = pin;
    _count = count;
    _index = 0;
void Thermo::begin(){
  _ow.begin((uint8_t)_pin);
  //_ow =(OneWire)new OneWire((uint8_t)_pin);
  _thermo = (byte**) malloc(_count * sizeof(byte*));
  for(int row = 0; row < _count; row++){
    _thermo[row] = (byte *)malloc(thermoSize * sizeof(byte));
void Thermo::addThermo(byte *thermo){
  if(_index > _count){
    return;
  for(int i= 0; i < thermoSize; i++){
    ((byte*)_thermo[_index])[i] = thermo[i];
  display();
void Thermo::display(){
  if (_index < _count &&
  OneWire::crc8((byte*)_thermo[_index], 7) != ((byte*)_thermo[_index])[7]){
    Serial.println("but it doesn't have a valid CRC!");
  else {
    for (int i = 0; i < thermoSize; i++){
      if (((byte*)_thermo[_index])[i] < 9){
        Serial.print("0");
      Serial.print(((byte*)_thermo[_index])[i],HEX);
      if (i<7){
        Serial.print("-");
    Serial.println("");
I have tried to find somewhere where it explains what is going on and couldn’t find anything useful.
If anyone can give e a pointer, either in what to change or where to look, I would appreciate it
Thanks
You have to include OneWire.h in your main sketch, or the arduino IDE won’t link it in.
Also, it’s not a great idea to #include “…/OneWire/OneWire.h” because there are two places people can put libraries. Just say #include <OneWire.h> and the IDE will tell the preprocessor where to find it.
Thank you.
I put the relative path to the OneWire library in because I couldn’t figure out how to make it work.
I appreciate your help.
I have a very basic question. In order to make this work in general, does the library I want to wrap has to provide a constructor with no arguments? For example SoftwareSerial does not provide such a constructor.
Is this true?
No, but the wrapper class can't have a no argument constructor, either, then, unless it is to make assumptions about what to pass to the wrapped class's constructor.
If you have a class, Wrapper, you can have a constructor, Wrapper(int rxPin, int txPin), and have that constructor invoke the wrapped class's constructor at the same time.
Wrapper::Wrapper(int rxPin, int txPin) : _serial(SoftwareSerial(rxPin, txPin))
  // Do whatever else the constructor needs to do
where _serial is an member of the Wrapper class, of type SoftwareSerial.
Now I can do almost all object oriented code for y arduino projects.
Thanks for your help.
I guess I need to learn c++ better.
