undefined references in static class ???
Linker undefined reference … I guess.
At the end of the compile of a large program (20 classes - 10 libraries) I get the following:
_variables are defined and implemented as private variables in log.h/.cpp (see attached test References sketch). They are all referenced in json.cpp.
Any suggestions on how I can get to the bottom of this?
Thanks - Abbott
Error (.text+0x2de): undefined reference to LogClass::_vacuumPsi
Error (.text+0x2e0): undefined reference to LogClass::_vacuumPsi
Error (.text+0x2e8): undefined reference to LogClass::_vacuumPsi
Error (.text+0x2ea): undefined reference to LogClass::_vacuumPsi
Error (.text+0x306): undefined reference to LogClass::_flowTot
Error (.text+0x308): undefined reference to LogClass::_flowTot
Error (.text+0x310): undefined reference to LogClass::_flowTot
Error (.text+0x312): undefined reference to LogClass::_flowTot
etc …
References.zip (353 KB)
I figured this out...finally.
I had declared my static variables as private in the header.
WHen I moved them to the class body(removing the private: and LogClass:: from the property.
This was a week from hell for me.
Static variables are handled a bit different than normal member variables.
There are 2 ways:
  1. in class definition: the static variable must be a constexpr.
    (Edit: constexpr is read only)
class A
   static constexpr int num = 0;
  1. declare your variable in the header, but define it in the cpp file.
.h
class A
   static int num;
.cpp
int A::num = 0;
