Under using Scheduler library-expected unqualified-id?
Now I'm trying to use Scheduler library, but IDE prints error.
I cannot understand what this message mean.
this is error message and code.
error message:
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Due (Programming Port)"
Using library Servo in folder: C:\Program Files (x86)\Arduino\libraries\Servo
Using library Scheduler in folder: C:\Program Files (x86)\Arduino\libraries\Scheduler (legacy)
C:\Users\robo3\AppData\Roaming\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++ -c -g -Os -w -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -MMD -mcpu=cortex-m3 -DF_CPU=84000000L -DARDUINO=10605 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON -DUSB_MANUFACTURER="Unknown" -DUSB_PRODUCT="Arduino Due" -IC:\Users\robo3\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/libsam -IC:\Users\robo3\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/CMSIS/CMSIS/Include/ -IC:\Users\robo3\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\system/CMSIS/Device/ATMEL/ -IC:\Users\robo3\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\cores\arduino -IC:\Users\robo3\AppData\Roaming\Arduino15\packages\arduino\hardware\sam\1.6.4\variants\arduino_due_x -IC:\Program Files (x86)\Arduino\libraries\Servo\src -IC:\Program Files (x86)\Arduino\libraries\Scheduler C:\Users\robo3\AppData\Local\Temp\build4926925755840420610.tmp\DUE_MULTISERVO.cpp -o C:\Users\robo3\AppData\Local\Temp\build4926925755840420610.tmp\DUE_MULTISERVO.cpp.o
DUE_MULTISERVO.ino: In function 'void setup()':
DUE_MULTISERVO.ino:17:12: error: expected unqualified-id before '.' token
DUE_MULTISERVO.ino (488 Bytes)
That you got from?
  Scheduler.startLoop(loop1);
Your instance is NOT called Scheduler...
