Understand a library and print the value of a struct
Hello everybody, I’m a rails developer and I have basic knowledge of arduino and c/c++
I 'm writing an alarm system using the Linkit On as board and some bluetooth LE sensors, and to capture the info broadecasted by the sensor I’m using a library.
Here is a portion of the library with the function I’m trying to change:
int SMSGateway::buttonsPressed(int num)
  LGATTDeviceInfo info = {0};
   typeBLEInfo mInfo;
   int numberAlert = 0;
   for (int i = 0; i < num; i++)
      c.getScanResult(i, info);
      #ifdef _DEBUG_INFO
      Serial.printf("[LGATTC ino]dev address : [%x:%x:%x:%x:%x:%x] rssi [%d]",
      info.bd_addr.addr[5], info.bd_addr.addr[4], info.bd_addr.addr[3], info.bd_addr.addr[2], info.bd_addr.addr[1], info.bd_addr.addr[0],
      info.rssi);
      #endif
      int lenAdvertData = info.eir[8];
      memcpy(&mInfo, &info.eir[9], lenAdvertData - 1);
      memcpy(&mInfo.nameBLE, &info.eir[9 + lenAdvertData + 2], 12);
      Serial.printf(mInfo.uuid);
      if(memcmp(myUuid, mInfo.uuid, 16 ) == 0){
          if(mInfo.minor[1] == 0x12 || mInfo.minor[1] == 0x11){
             memcpy(&BLEInfo[numberAlert], &mInfo, 32);
             numberAlert++;
             #ifdef _DEBUG_INFO
             Serial.println("\n<<<<<< Alert >>>>>>\n");
             #endif
          }else if(mInfo.minor[1] == 0x02){
             #ifdef _DEBUG_INFO
             Serial.println("\n<<<<<< Normal >>>>>>\n");
             #endif
  return numberAlert;
I’m trying to understand the code and I understand that buttonsPressed is a function of the SMSGateway library and this function return an integer with the amount of alarm triggered.
The function was written by someone that use some bluetooth buttons… I have a sensor (that works as a button but with a different broadcasted value )
Info is an object of type LGATTDeviceInfo, and according to the api library is
typedef struct {
  LGATTAddress bd_addr;
  int32_t rssi;
  uint8_t eir_len;
  uint8_t eir[256];
} LGATTDeviceInfo;
LGATTAddress bd_addr ->Address of Bluetooth 4.0 device.
int32_t rssi -> Received signal strength indication.
uint8_t eir_len -> Length of equipment identity register.
uint8_t eir[256] -> Content of equipment identity register.
mInfo is a typeBLEInfo, and this is declared by the library
 typedef struct {
  byte uuid[16];
  byte major[2];
  byte minor[2];
  byte nameBLE[12];
}typeBLEInfo;
The function scan every second for BLE devices and return for every device found a LGATTDeviceInfo object.
This serial print return me the objects
      info.rssi);
The address is ok, the rssi (signal strength) is ok
At this point I cannot understand nothing in the code: I must read the “uuid” and the “nameBLE” and I cannot find a way to print these value in console. I need of course to adjust this conditional to trigger the alarm
             numberAlert++;
Any hint?
I must read the "uuid" and the "nameBLE" and I cannot find a way to print these value in console.
If "uuid" means "the uuid member of the minfo object", I can't see why you can't see the data. Reading the data doesn't make a lot of sense. There data is there. Use it.
The same holds true for nameBLE.
As you can see I try to add
In the console I have for every device the same 8 bit string...
And also if I use
Serial.printf(mInfo.nameBLE);
Same data printed in console...
:frowning:
As you can see
Well, no, I can't.
I try to add
Where?
Post your code.
   typeBLEInfo mInfo;
      #ifdef _DEBUG_INFO
      info.rssi);
      #endif
             numberAlert++;
             #ifdef _DEBUG_INFO
             #endif
             #ifdef _DEBUG_INFO
             #endif
  return numberAlert;
Before the if I add
Same value for every device.
Is there a way to print mInfo?
Which leads me to believe that you are printing data about the receiver, not the transmitter.
Don't know.
Every book I read about Arduino is too basic.
For example I cannot understand the & in front of some variable in the memcpy function...
I try to find an advanced programming book.
It's the address-of operator.
The memcpy() function needs to know where to copy data to/from. So, you pass it the address of the array to read from/write to.
Ok, I understand my fault.
I read a C++ manual and I understand that eir[256] is an array with 256 element. In ruby the syntax is different so I wrong. I loop in the array and I print the values and now they are different
[LGATTC ino]dev address : [20:c3:8f:86:b5:96] rssi [-75]
2
1
6
3
2
0
160
16
9
82
69
67
65
77
53
50
71
74
88
48
49
50
53
49
5
18
80
0
80
0
2
10
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
196
17
31
240
0
0
Now I must understand how can I transform these values into the uuid and the name of my device... :smiley:
The snippets of code that you posted show you that. The length of the uuid value is in eir[8]. The uuid value starts in eir[9]. The BLEName starts in eir[9 + lenAdvertData + 2], where lenAdvertData is the value in eir[8].
Of course now I understand.
I'm a ruby developer, eir[256] is the item of the array eir at index 256 :smiley:
robypez:
Yes. Except that eir only has 256 elements, so the index values run from 0 to 255.
