Understanding a datasheet.
I currently trying to i2c a synthersiser chip on a transmitter, but I cannot understand the datasheet at all.
I currently have this thread going http://arduino.cc/forum/index.php/topic,165805.0.html if you want to read the background on this post.
The chip im trying to control is http://datasheet.eeworld.com.cn/pdf/MITEL/86480_SP5055.pdf its not a big pdf file and the info required is on page 4,
I am talking to the chip but im not talking to it correctly.
  Wire.beginTransmission(0x61);
  Wire.write(40);
  Wire.write(40);
  Wire.write(40);
  Wire.write(10);
  int r = Wire.endTransmission();
  Serial.println(r)+'\n';
  delay(550);
The above code will set the transmitter to about 1285mhz. I know this is the wrong way to do talk to this chip but it seems to be the only way that's working for me.
The datasheet says "The programmed frequency can be calculated by multiplying the programmed division ratio by 16 times the comparison frequency Fcomp."
Fair enough, but how tdo I convert that to a byte (8bits).
Thanks.
You split the 16 bit number into two bytes. When you talk to the chip you send five bytes at a time.
Upper = value >> 8;
Lower = value & 0xff;
The datasheet says “The programmed frequency can be calculated by
comparison frequency Fcomp.”
Your comparison frequency is Xtal/512 = for 4MHz crystal it is 7.8kHz
So your output frequency = DIVIDER * 16 * Xtal/512
DIVIDER (16bit unsigned) = frequency/(16*Xtal/512)
Mind the DIVIDER is 15 bits only. Then follow GM’s advice:
unsigned char byte2, byte3;
unsigned int divider;
unsigned long frequency;
unsigned long xtal;
divider = (frequency * 32L) / xtal ;
byte2 = (divider >> 8) & 0x7F;  //high byte
byte3 = divider & 0xff; //low byte
A simple algorithm :slight_smile:
Thanks pito I will give that a try.
Question, I have to send 5 bytes to this device to get it to do something, the first byte sent should be the address.
Is the Wire.begineTransmission(0x60); classed as the first byte?
Have tried the following code and still no joy …
  //Wire.beginTransmission(0x60);
unsigned long frequency = 1248.500;
unsigned long xtal = 7.8;
Wire.write(11000010);
Wire.write(byte2);
Wire.write(byte3);
Wire.write(11001110);
delay(550);
unsigned long frequency = 1248.500; unsigned long xtal = 7.8;
shall be:
unsigned long frequency = 1248500000;  // in Hz
unsigned long xtal = 4000000; // Xtal 4MHz in Hz
or better
unsigned long frequency = 1248500;  // in kHz
unsigned long xtal = 4000; // Xtal 4MHz in kHz
Wire.beginTransmission(0x61); Wire.write(11000010); Wire.write(byte2); Wire.write(byte3); Wire.write(11001110); Wire.write(11001110);
I think, based on the datasheet, you have to send 5bytes only:
Wire.beginTransmission(0x61);  // byte1 = address (7bit only) (11000010>>1)
Wire.write(byte2);
Wire.write(byte3);
Wire.write(B11001110); // byte4
Wire.write(B11001110); //byte5
Pito, what can i say ... you are the best.
Just been back out to the workshop and tried your code, and it worked perfectly.
You have made me a very happy man tonight.
I would of never been able to work that out.
Thanks so much.
This compiles at least :slight_smile:
It will increment the frequency by 1MHz each loop.
#include <Wire.h>
  Wire.begin(); // join i2c bus (address optional for master)
  unsigned long freq_step = 1000; // in kHz
  while(1) {
    byte2 = (divider >> 8) & 0x7F;  // high byte
    byte3 = divider & 0xff; // low byte
    Wire.write(byte2); // byte2
    Wire.write(byte3); // byte3
    Wire.write(B11001110); // byte5
    frequency = frequency + freq_step; //increment the frequency
    Serial.print(r);
    Serial.println("\n");
    delay(2000);
Pito, thanks for the second bit of code, will give it a try in the morning.
Will let you know if it works ok.
Thanks.
Pito, your scan code works perfectly.
Im currently adding a LCD and buttons to the project, these chips have a signal detector on them so i shall be adding a auto scan function to it as well now using your scan code.
I cannot thank you enough for your time helping me.
Once i have finished it, i will post the complete code on here.
Thankyou.
