Understanding a for loop
Hello, I need help with this for loop please. What I'm trying to accomplish is: The LDR (later will be a PIR) turns on LED 1 for 5 seconds and blinks the LED 2 on and off. But then stops after a short time. I thought I could adjust the time to turn off by adjusting the for loop. Now it just stays on while the LDR is covered.
//Umpteenth try to get one LED on for 5 seconds and the other Blink while its on then turn itself off.
unsigned long previousMillisLED_long = 0;   //Set up PreviousMillis
unsigned long previousMillisLED_short = 0;
int ldrPin = A0;
int intervalLED_long = 5000;    //Set up Intervals
int intervalLED_short = 200;
byte ldrState = 0;
boolean LED_2state = false;
boolean LED_3state = false;
  pinMode(A0, INPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  int ldrState = analogRead(ldrPin);  //set up LRD
  Serial.print(ldrState);
  if (ldrState <= 300)  {                        //If it triggers
    for (int i = 0; i < 20; i++) {                 // repeat twenty times
      digitalWrite(2, HIGH);
      if ((unsigned long)(currentMillis - previousMillisLED_long) >= intervalLED_long) {
        LED_2state = !LED_2state;
        previousMillisLED_long = currentMillis;
      if ((unsigned long)(currentMillis - previousMillisLED_short) >= intervalLED_short) {
        LED_3state = !LED_3state;
        digitalWrite(3, LED_3state);
        // save current time to pin 3's previousMillis
        previousMillisLED_short = currentMillis;
  else {                                             //shut all off
    digitalWrite(2,  LOW);
    digitalWrite(3,  LOW);
Putting millis() timing inside a for loop is a waste of effort - there can be no cooperative multitasking happening until the loop exits. A simple delay() would work identically and be easier to read and troubleshoot.
If you need cooperative multitasking, you need to eliminate the for loop altogether and use a state machine instead.
aarg:
Thanks, but if I delay the long LED will this not stop the blinking LED from working? My hope is to have both work at the same time.
You don't want to be using a for() loop for timing. Look at the BlinkWithoutDelay example to see how to keep track of elapsed time without preventing your code from doing other things. Basically, like this
unsigned long startTime = 0;   // time of trigger
unsigned long previousBlinkTime = 0;
const int ldrPin = A0;
const int led1Pin = 2;
const int led2Pin = 3;
const unsigned long triggerDelay = 5000;    //Set up Intervals
const unsigned long blinkDelay = 200;
bool isTriggered = false;
  pinMode(ldrPin, INPUT);
  pinMode(led1Pin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  if (ldrState <= 300 && isTriggered == false) {
    // initial trigger so start timing
    isTriggered = true;
    startTime = currentMillis;
    previousBlinkTime = currentMillis;
    digitalWrite(led1Pin, HIGH );
    digitalWrite(led2Pin, HIGH );
  if ( isTriggered == true ) {
    // trigger has already happened so check timing
    // first check if time to blink led2
    if ( currentMillis - previousBlinkTime >= blinkDelay ) {
      digitalWrite(led2Pin, !digitalRead(led2Pin) );  // toggle the led
    // check if it is time to finish
    if ( currentMillis - startTime >= triggerDelay ) {
      // all done so turn everything off and reset trigger so it can happen again
      digitalWrite(led1Pin, LOW );
      digitalWrite(led2Pin, LOW );
Thank you. I will have to read it over so I can understand whats going on.
