Understanding & in an if statement
Hi everyone,
I am working on modifying some code for a control system at work. The guy who initially wrote the code retired a while back and is no longer available for contact. I was wondering if anyone could help me understand the following statement:
if (nValueY >= -100 && nValueY <= 100 && nValueX >= -100 && nValueX <= 100)
nJoyY = 0;
nJoyX = 0;
The only thing I don't understand from this line is the double &&
Can someone please help me understand this?
This is the standard C/C++ logical AND operator:
https://en.cppreference.com/w/cpp/language/operator_logical
Your code got a bit mangled - I think you meant this?
   nJoyY = 0;
   nJoyX = 0;
It's wise to use parentheses, as there are some common pitfalls with precedence here:
if( (nValueY >= -100) && (nValueY <= 100) && (nValueX >= -100) && (nValueX <= 100) )
   nJoyY = 0;
   nJoyX = 0;
So that's checking that both the values are in the range -100..+100 (inclusive).
That is actually how the code is written exactly how I am looking at it which is probably why I am so confused. (I didn't write it, I'm just trying to modify it and clean it up a bit)
Just to reiterate, to make sure I am understanding the last 2 replies correctly:
&amp;&amp;
is just && correct?
(also I apologize, I didn't realize the forum was already changing my &amp to a & automatically)
Thank you so much for your help
Right, just &&. In forum posts please use the < CODE> tag to prevent changes to the entered code.
Yes, that's right.
Note that the '<' (less than) and '>' (greater than) had also been mangled.
