Understanding boolean function.
I want to return a function whether it is true or false. If it's true run this code, else do not run this code.
if(irrecv.decode(&results))
//If its true run this code
resultValues();
irrecv.resume();
void resultValues()
switch(results.value)
case 1886400719:
if(isOn)
 Serial.println("On");
 isOff = true;
 isOn = false;
returnTrue();
else if(isOff){
 Serial.println("Off");
isOn = true;
isOff = false;
returnFalse();
How to I pass the value of isOff and isOn on the void loop? Thanks
Indenting your code is crucial. Either get into the habit, use a programming editor to help you, or press control-T in the IDE editor.
Without the complete program, I can't provide a complete answer. Here's a guess, which might be a waste of my time if I'm guessing wrong:
  if (irrecv.decode( &results ))
    resultValues( results ); // return value not used?
    irrecv.resume();
bool resultValues( ResultsTypeNameHere & results )
  switch(results.value) {
    case 1886400719:
      if(isOn) {
        Serial.println( F("On") );  // F macro saves RAM
        isOn = false;
        isOff = true;
        return true; // but not tested by calller...
      } else if (isOff) {
        isOn = true;
        isOff = false;
        return false;
If you want to return a value from your function, you put the return type before the function name (instead of void).
But I have to ask, are isOn and isOff always opposite of each other? If they are, you should only use one of them. Using isOn reads the nicest:
    irrecv.resume();
    case 1886400719:
      Serial.println( isOn ? F("On") : F("Off") );
      isOn = !isOn;
      return !isOn; // really? return "is off"?
The ternary operator ? and : is a little if-then-else statement that lets you write one print statement instead of 5 lines for this simple test. I do not recommend it for if tests that are more complicated.
The exclamation mark is the logical NOT operator (i.e., invert or negate). It's used to toggle isOn.
Cheers,
/dev
