Understanding BWD, and general coding.
Hello, I have combined the BWD code from the arduino website with another code used for the HCSR04 Ultrasonic Sensor. My sensor always reads zero and my LED does not blink continuously, only once. Here is the code.
const int triggerPin = 12; //Trig pin
const int echoPin = 11; //Echo pin
const int ledPin = 5;
pinMode(triggerPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(ledPin, OUTPUT);
int Duration, Distance;
digitalWrite(triggerPin, HIGH);
delayMicroseconds(1000);
digitalWrite(triggerPin, LOW);
Duration = pulseIn(echoPin, HIGH);
Distance = (Duration/2) / 29.1;
Serial.print(Distance);
Serial.print(" cm");
int ledState = LOW; //integer used to set LED Status
unsigned long previousMillis = 0;
const long interval = 1000;
if (currentMillis - previousMillis >= interval) {
  if (ledState == LOW) {
     ledState = HIGH;
    ledState = LOW;
  digitalWrite(ledPin, ledState);
P.s I hope this was posted in the correct forum.
  delay(500);Why, in a program that uses the BWOD principle ?
Why initialise previousMillis ? Very soon after the program starts currentMillis - 0 will always be greater than interval.
Right sorry that was probably an issue on it's own, I meant to disable the delay.
Do you know why the sensor would be reading 0 continuously though? I saw many posts about the issue and I have tried both the NewPing library and my own attempts but I couldn't get it to work.
Is it the sensor or my programming?
Edit:
     ledState = HIGH;
    ledState = LOW;
Still not blinking more than once. Maybe I'm doing something wrong in the loop?
Hello try moving these two lines to the top of your sketch
Make this global.
LarryD:
Make this global.
or static.
Or static :frowning:
This is a global community. :slight_smile:
This is a dynamic global community.
But we still like "static"
The standard trigger sequence for the ultrasonic sensor looks like the modification below
//digitalWrite(triggerPin, HIGH);
//digitalWrite(triggerPin, LOW);
delayMicroseconds(2);
delayMicroseconds(10);
