Understanding Code
Hi Guys,
Trying to understand this code.
Anybody willing to add some sensible comments.
Regards
Peter
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
int MIN_TEMP = 16;
int MAX_TEMP = 28;
pinMode(9,OUTPUT);
sensors.begin();
  float temperature = getTemperature();
  int voltage = temperatureToPWM(temperature);
  analogWrite(9,voltage);
float getTemperature()
  float temperature =0;
  sensors.requestTemperatures(); // Send the command to get temperatures
  temperature = sensors.getTempCByIndex(0);
  Serial.println(temperature);
  return temperature;
int temperatureToPWM(float temperature)
  float temp=0;
  float voltage = 0;
  temp = temperature*10;
  voltage = map(temp,MIN_TEMP*10,MAX_TEMP*10,0,250);
  return voltage;
Which parts don’t you understand?
This line probably does not need a comment:
map uses integer-only arithmetic, so I don't know why you'd want to use it on a float.
pinMode(9,OUTPUT); // redundant; could be removed
Which parts don't you understand?
Yes, this is the first comment that comes to mind. :slight_smile:
AWOL thanks for the useful feedback.
I shall re-phrase my question.
Would somebody add comments to the code to help me understand, as its is confusing me at the moment.
Regards
Peter
Can you say what you are confused by?
Apart from not giving pin 9 a useful name, it looks pretty straightforward, if a little long.
This I understand :slight_smile:
const int analogInPin= 0; //Potentiometer wiped connect to pin A0
const int analogMeterPin= 9; //Analog output pin connected to the meter
int sensorValue= 0; //value read from the potentiometer
int outputValue= 0; //value output to the terminal D9 (analog out)
void setup ()
//nothing in setup
sensorValue= analogRead(analogInPin); //this gives us the analog voltage read from the potentiometer
outputValue= map (sensorValue, 0, 1023, 0, 255); //scale for analog out value
analogWrite (analogMeterPin, outputValue); // write the analog out value
This I understand
But you can't seem to tell us what you don't understand.
//Include the libraries we need
//Data wire is plugged into port 2 on the Arduino
//Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
//Pass our oneWire reference to Dallas Temperature.
//set the lower bounds
int MIN_TEMP = 16;
//set the upper bounds
int MAX_TEMP = 28;
  //Not really needed
  pinMode(9, OUTPUT);
  //Set baud rate, start serial port
  //Start up the library
  sensors.begin();
  //read the temperature
  //convert temperature to an equivalent PWM value
  //send PMW converted value to a PWM pin
  analogWrite(9, voltage);
  //wait for 1/2 second
  float temperature = 0;
  //Send the command to get temperatures
  //Get temperature, use the function ByIndex, from the first sensor.
  //send to serial monitor
  //return value to calling routine
  return temperature;
  float temp = 0;
  float voltage = 0;
  //adjust to temperature keep the tenths digit
  temp = temperature * 10;
  //as mentioned should use 'integer'
  //See: https://www.arduino.cc/reference/en/language/functions/math/map/
  //filter values between lower to upper bounds, *10 as we did tenths decimal adjustment previously
  //convert to equivalent 0-250 for PWM
  voltage = map(temp, MIN_TEMP * 10, MAX_TEMP * 10, 0, 250);
  //return to calling routine the mapped conversion
  return voltage;
LarryD that helps me a great deal:)
Many thanks
Peter
