Maybe its just me, but it strikes me as logical, that when you get an error code back from trying to compile the sketch, ie:
"Turret5.cpp:50:41: error: expected identifier before ‘(’ token"
the address "50:41" should refer to the location of the error.
except on mine it doesn't, the first figure is several lines out, and i have no idea what the 41 means....
Unfortunately, the compilation errors are generated after the IDE makes its additions to your sketch, so the line numbers are a bit out. The second number probably (I haven't looked at it closely) relates to the error message.
OllyR:
The IDE adds a couple of lines to your code before the compiler gets it. However, it generally backs out number from the error before printing it in the status window.
Also, keep in mind the compiler doesn't always identify the line that is the actual problem. It is just the line where the compiler ran into a problem. This complicates the issue of identifying where the issue occurred.
OllyR:
I have not seen an error message like that before. Since you have an example, you might want to post your code.
i sorted that one, i had put brackets around something that didnt need them.
Thanks for the update though. I was convinced i was being dim, but its not just me that struggles to make use of the returns.
I have been using Arduino since a month. A week ago it was all good with all the necessary libraries. But one day it cant even compile the program it did a week ago. I have tried various versions of Arduino IDE since.
Error -
C:\Users\x\Documents\Arduino\libraries\PS2X_lib\PS2X_lib.cpp: In member function 'void PS2X::read_gamepad(boolean, byte)':
C:\Users\x\Documents\Arduino\libraries\PS2X_lib\PS2X_lib.cpp:104:53: warning: narrowing conversion of 'motor2' from 'byte {aka unsigned char}' to 'char' inside { } [-Wnarrowing]
c:\program files (x86)\arduino\hardware\tools\avr\bin../lib/gcc/avr/4.9.2/../../../../avr/bin/ar.exe: unable to rename 'core\core.a'; reason: Permission denied
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
Invalid library found in C:\Users\x\Documents\Arduino\libraries\Ultrasonic-HC-SR04-master: C:\Users\x\Documents\Arduino\libraries\Ultrasonic-HC-SR04-master
Invalid library found in C:\Users\x\Documents\Arduino\libraries__MACOSX: C:\Users\x\Documents\Arduino\libraries__MACOSX
Could someone explain me this error message generated while uploading the code using arduino ide:
"Sketch uses 11038 bytes (38%) of program storage space. Maximum is 28672 bytes.
Global variables use 580 bytes of dynamic memory.
Found programmer: Id = "€"; type = …
Software Version = €.; Hardware Version = "
