Understanding Concepts About Arrays
In case it's still not clear to you, that code doesn't update your global variable. Because that line starts with the word int (or any other type), it is declaring a new variable, not updating an existing variable.
It's allowed, in C/C++, to have more than one variable with exactly the same name. But when you do that, they can't be in the same "scope". In this case, your global variable called timeInterval is "in scope" everywhere in the code except inside the chngFlashRate() function, where the other, non global variable is in scope. The second timeInterval variable makes a hole in the scope of the global one!
The most important thing to learn about interrupts is when to use interrupts and when not to use them. As a beginner, you won't know. Here's a tip: as a beginner, if you think you should be using interrupts, you are probably wrong!
Thanks. This is in essence what I was trying to figure out through the forum and understand why code like this is not supported.
So the "memcpy” function seems to be the closest to achieve something like this?
Also asking if writing comparative case arguments was possible instead of going element-by-element, which apparently is not allowed either, i.e.
if (exampleArray_a[] != exampleArray_b[]){}
These are what I was struggling to learn and i understand now i cannot to this.
What happens if you do Serial.println (sizeof (unsigned int));?
You cannot assign full arrays (you can initialize it). You cannot compare arrays.
But you can make functions for comparation of arrays or for assignin values to them.
Something like this:
bool are_equal(int a[], int b[], int len) {
  for (int i=0; i<len; ++i)
    if (a[i] != b[i]) return false;
  return true;
The Arduino is programmed in C++ with hardware specific extensions such as digitalWrite(), digitalRead() etc
You cannot copy whole arrays using a simple = operator in C/C++ which is why you can't do it in the Arduino environment
However, you could write your own copyArray() function and use that to copy one array to another using memcpy() or a for loop if you need to do it in several places in the sketch and/or if you require different arrays to be copied in different circumstances
Maybe Operator overloading - Wikipedia could help you - you may overload usual operators to accept unusual arguments and manage them unusual ways. Operators in C and C++ - Wikipedia
But it would be difficult, error prone and hard to use in other projects.
A simple overload oth == operator will not work.
C++ does not know the size of an array. So you need an extra argument to tell the amount of elements (as you (@gilhad )suggested in post #24).
In C-descendant/related languages, [] is the indexing operator. So broadly
var x = {2, 4, 6};
print(x[2]);
C/C++ is particular in allowing the [] on left side of the =, tied to the variable name as part of the declaration.
int32_t y[] = {5, 7, 9};
int32_t *z = y;
Serial.println(sizeof(y));
Serial.println(sizeof(z));
Serial.println(z[2]);
Those two are similar, but z is "just a pointer"; while y "decays to a pointer" but also knows its size, that it has 3 elements. sizeof(z) is the size of a pointer (2 or 4 bytes), while sizeof(y) is 3 times 4 bytes. The indexing operator works fine with a pointer.
By having no argument in the brackets, the compiler will count the number of elements and size accordingly. If you specify the count, the compiler will balk if there are too many elements, but is fine if you specify too few (leaving the gap with their default values, zero or garbage).
This initialization is the only time that name[] is allowed, with no arguments. After that the brackets are used to specify a single element. Note that the initialization is not "a lot of work" by itself. The literal array on the right of the = might be arbitrarily large, but initializing the array variable is just copying a pointer to the first element.
So oldArray[] = newArray[] is not allowed syntactically, in any C-like language. Other languages might allow oldArray = newArray, which simply results in the array reference being overwritten. But in C/C++, this is some kind of "invalid array assignment" error, even when the arrays are the same size. You can think of it as "too much work" in principle. The compiler does not want to commit to copying an arbitrary number of elements with a single assignment. You need to use a function like memcpy. But this is allowed:
  struct {
    int32_t i[3];
    float f[3];
  } a, b{{1, 2, 3}, {0.5, 0.25, 0.125}};
  a = b;
  Serial.println(sizeof(a));
  Serial.println(a.f[2]);
Even if the struct is arbitrarily large (and contains arrays), it's still a "single object", and so assignment by copying is allowed.
Which is not to suggest that you do that. If you have three related values, instead of an array, you might use a struct like this
struct WithBetterNames {
  int first;
  int second;
  int third;
} before{LOW, LOW, LOW}, after{HIGH, HIGH, HIGH};
Serial.println(before.third);
before = after;
"Easy"/naive comparison of structs requires C++20 with the "spaceship operator" <=>
  int first;
  int second;
  int third;
  auto operator<=>(const WithBetterNames&) const = default;
Serial.println(before == after);
Some boards like ESP32 (probably) have it, while AVR does not.
